PO174 reading....need advice
Old Feb 17, 2015 | 06:50 AM
baylward's Avatar
Default PO174 reading....need advice
I have an OBDII reading of PO174 on a 2006 S-Type 4.0 with 58,000 miles. What is the probable cause and where should I start?
Old Feb 17, 2015 | 08:29 AM
joycesjag's Avatar
Start with getting either the motor size or the MY correct. Most likely a vacuum leak though.
Old Feb 17, 2015 | 10:29 AM
NBCat's Avatar
+1 on providing correct MY or engine. The 2006 S-Type was fitted with the 4.2 litre unit.
The code is P0174 and a vacuum leak is the most likely cause. Fuel trims will help confirm this as well.
Old Feb 18, 2015 | 12:01 PM
Jumpin' Jag Flash's Avatar
From: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
Next, you should do a search on the Jag Forum for code P0174 (it's a zero, not the letter "O"). There are lots of threads on this code. As mentioned above by one of the most esteemed members of this forum, it's most likely a vacuum leak, as it was on my car. Relatively inexpensive to repair, but you MUST start by knowing exactly what MY and engine you have.
Old Feb 18, 2015 | 12:41 PM
joycesjag's Avatar
Agreed NBCat's knowledge is certainly very much appreciated!
Old Feb 24, 2015 | 04:30 PM
baylward's Avatar
Yes....it is a 4.2 L Where can I find a diagram of all of the vacuum lines to check. I tried last nite but was unsuccessful in finding a leak. Perhaps I just haven't checked the right one. I heard that some models must be checked with propane and not carb cleaner. Any truth to that??? I cleaned maf sensor and checked all connections that I could find by spraying cleaner but I feel like I might have missed some. Thanks for your help
Old Feb 24, 2015 | 06:06 PM
NBCat's Avatar
The quickest and least dangerous way to check for a vacuum leak is by performing a smoke test under bright lights so even a very small leak becomes evident.
Most competent repair shops can perform a smoke test and locate vacuum leaks quickly if you do not have access to such equipment.
mikiep
Dec 20, 2019 07:37 PM
workworkwork
Oct 23, 2015 10:26 AM
adam699
Oct 13, 2015 05:53 PM
Jässe in Pälkäne
Oct 2, 2015 05:38 AM
mbam504
Sep 29, 2015 04:56 PM
