Power Steering Pump Replacement Advice
Old Feb 9, 2013 | 02:51 AM
Running Man's Avatar
Default Power Steering Pump Replacement Advice
Hello, I have recently discovered that I have a leak from my power steering pump and am thinking about repacing it myself, however I always think its a good idea to firstly find out how this is done and if it is difficult. I would like to ask anyone on the forum if they have done this before and if they have any good tips, is it difficult and also if I need any special tools to carry out the job. The engine on the car is the 2.5.
Old Feb 10, 2013 | 11:54 PM
NBCat's Avatar
Originally Posted by Running Man
Hello, I have recently discovered that I have a leak from my power steering pump ... I always think its a good idea to firstly find out how this is done and if it is difficult...The engine on the car is the 2.5.
If you intend to replace the pump yourself, obtain the JTIS manual, which will detail the operations necessary to remove and replace the pump and refill with the correct fluid.
It is also a good idea, if you have not already done so, to obtain a set of spanners (wrenches) that include a short 18mm in case the pressure fitting is that size as they can be difficult to reach on some cars.
Old Feb 12, 2013 | 06:39 AM
Thanks for the advice. I currently have the JTIS manual but can not find any info on the power steering pump. Where is it?
Old Feb 12, 2013 | 08:44 AM
It's in the chassis section 211-02 subsection power steering - removal and installation.
Old Feb 14, 2013 | 07:10 AM
Thanks for info. I would just like to say that the forum is always very helpful and much appreciated.
rusty37
Jun 7, 2016 04:43 PM
NTL1991
XJ40 ( XJ81 )
Sep 24, 2015 09:09 PM
convincor
Sep 3, 2015 08:03 PM
jagy4321
Sep 3, 2015 07:56 PM
Calhale
Aug 29, 2015 10:39 AM
