Procedure to Bleed air from Coolant system
Old Jan 6, 2009 | 01:46 PM
djdex's Avatar
Default RE: Procedure to Bleed air from Coolant system
Run the car at fast idle - say about 1500rpm, with the heating set to max and the expansion tank cap off, for 5 minutes.
That's the main part of the procedure as I recall. There is a bleed valve on one of the cross pipes - large plastic crosshead screw, you're supposed to slack it off, add coolant till it flows out of the bleed, close the bleed and carry out the above. Many people report little or no effect with the bleed valve, so I'd just fill the expansion tank to halfway, do the above while watching the level and topping up as required.
Old Jan 7, 2009 | 05:57 PM
03JagSTR's Avatar
The only bleeder valve/screw that I am aware of is on the coolant expansion tank.
jdzubas
Oct 4, 2015 09:14 AM
Corycarlo
Sep 5, 2015 11:41 AM
Bcrary3
Sep 3, 2015 03:48 PM
OkieTim
Sep 2, 2015 12:48 PM
