Project Resurrection
Old Apr 11, 2016 | 02:41 PM
seagates5's Avatar
Default Project Resurrection
Bought a V8 Stype about a year ago thinking it was a easy spark plug fix but it wasn't. After vacuum, compression, and leak down test I had concluded that a new engine was needed due to low compression on all cylinders cause by bad rings and probable rod knock. So it sat there for a yr and a buddy came by and looked at and said it's prob head gasket. I didn't think so because there was no coolant mixing. So I pressurized the tank and at 5 psi fluid came gushing down the back of the engine and will no longer hold pressure. So I think it might say it's safe to say it was the heads are bad. So the question is do I fix it or scrap it?
Old Apr 11, 2016 | 03:05 PM
JagV8's Avatar
Are you up to it? Which V8? Etc.
Only you know so far...
panza
Jul 25, 2009 02:39 AM
