Prophylactic fix now or sale?
Old Aug 5, 2014 | 06:25 PM
webbeing's Avatar
Default Prophylactic fix now or sale?
Hello all,
I have a 2000 S-type V8 since new. It has about 47K city miles. Aside from tires, brake pads, so far it went through two sets of coils, 4 window regulators, and one overflow reservoir. It ran fine a week ago. Unfortunately, it is waiting for a donor instrument cluster to run again. I just stumble across a number of posts concerning the transmission and chain tensioner issues which cause me to think should I just cut my losses and get out?
Replacing all the tensioners and chains probably cost about $3K parts and labor. Rebuilding the tranny valve body to add/replace with "SK Shift Kit, new Solenoid Block, and Sonax springs" probably cost about $1K parts and labor. Though I can turn a wrench (replacing above parts), I think these are too big a job for me. From the local paper the best I can get for the car is $6K - $7K, I don't know if the new owner would expect the tensioners and tranny improvement to be already done at this price.
If I spend the $4K for the tensioners and tranny, can I expect a reliable car going forward? Little things go wrong is fine, I rather avoid being stranded somewhere.
What is the likely hood that the tensioners and tranny last another 2 years or 5K city miles?
A great many thanks for your thought.
Old Aug 5, 2014 | 08:40 PM
Mikey's Avatar
$3K sounds way high to get the tensioners done but I'll let the V6 guys advise. I'd be surprised if you could get $6-7K for your car without them being done nor would I sell it without telling the buyer.
I'd hang on to the car, fix the tensioners immediately and then the transmission when it needs it, if ever.
Old Aug 5, 2014 | 09:19 PM
aholbro1's Avatar
What're you washing dinner down with tonight, Mikey? (I want some) V-6 guys don't have a tensioner issue. I'm persuaded the OP could surely find someone to do the tensioner replacement for $3k....but like you Mikey, I'd say he could also find someone competent to perform the task for less. IIRC, part-costs if you DIY are on the order of $800 but I may be wrong on that....as I said...I'm a V-6 guy with no worries on that issue.
I'm also dubious that a MY2000 would fetch $6k-$7k, even though it is one-owner/low mileage which will play in your favor for a sale.
+1 on Mikey's advice to renew those timing chain tensioners right way - you could be one or two starts from ruining an otherwise healthy engine with lots of mileage left in it.
Old Aug 5, 2014 | 09:56 PM
Mikey's Avatar
Ooops. This proves that successful multi-tasking is a myth. Half paying attention to TV and half watching what I'm writing makes for .
Brain meant 'pre-face lift' engine not V6. Fingers did not obey.
Old Aug 6, 2014 | 11:47 AM
tbird6's Avatar
I really must suggest dumping the car now. Get a 2003 and up model. A world of changes and not much money if you actually do want an S Type. Not that many people do.
Wolfy
May 28, 2024 08:06 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
42Ajd
Dec 30, 2015 09:45 AM
CaneCounsel007
Nov 13, 2015 09:05 PM
Richard_gib
Sep 12, 2015 07:08 PM
