Question about underside of the car...
Old May 18, 2008 | 04:59 PM
stdjrm17's Avatar
Default Question about underside of the car...
I have a 2003 S-Type 3.0 and under the car I had a plastic part start to drag on the ground and scrape. The part is about 4 foot by 3 foot and it looks like it is part of a covering for underenath the car. Not really sure if this is explaining it or not. I ended up removing the 4 bolts on the part and taking it off. What I am wondering is if this is something that was protecting an important part of the car like the brake lines or something. I figure one of the more tech guys would know the answer to this one.
Thanks,
Russell
Old May 18, 2008 | 05:40 PM
conipc's Avatar
Default RE: Question about underside of the car...
Most likely the pan that goes under the engine like a belly pan. The securing system is pretty poor ,with a kind of clip on the rear edges. It should secure with more than 4, in the center and at the edges.
Old May 18, 2008 | 09:06 PM
stdjrm17's Avatar
Do you know if it protects anything improtant on the car? In otherwards if I was to leave it off and not put it on would it be a super bad thing?
Old May 18, 2008 | 09:22 PM
ibjags's Avatar
i would replace it
it keeps damaging road debris from entering into the eng compartment
secured correctly would be 3 10 mm bolts on the frt
2 phillips screws behind that
and then 2 more 10mm bolts in the back
replace it and have peace of mind
hope this helps
Dz1rfj
Jul 17, 2018 10:29 AM
jdzubas
Oct 4, 2015 09:14 AM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
carcycle
Sep 7, 2015 10:22 AM
