Question to our experts
Old May 25, 2018 | 10:23 AM
mkontos's Avatar
Default Question to our experts
I lost the driving control of my STR, in a full rainy day and i hit the rear whel in the central wall of the highway . The result was to bend the rear bridge (suspension) and the whel is now leanig . So now i have to change the whole rear bridge. The question is : our STR have the same rear suspension with the V6 or are diferent, cause from V6 i can found a lot of good used parts here.
Thank you
Old Jun 4, 2018 | 01:12 AM
mkontos's Avatar
Default rear bridge (subframe)
The answer is that the s type V6 and the STR have the same rear subframe, the models after 2003, but notice, that some of them , they have not support for the electric rear brake.
Old Jun 4, 2018 | 06:13 AM
M-e-l-l-o-w's Avatar
You can use the official Jaguar Classic parts website to find all the part numbers you need and to see when the parts changed. (It looks like there was a change at vin L76999, at vin M45255 and then vin N70949.)
So if you have an 2003 Model Year car (with a 31Mxxxxx vin number) I guess you will need a sub frame from a 2002.5 (21M) model year car up to a 2007 model year car.
Here is a link:
https://www.jaguarclassicparts.com/uk/s-type-parts
As always any corrections to the above are most welcome.
Old Jun 5, 2018 | 10:23 AM
mkontos's Avatar
Default rear subframe
Thank you Mellow ,very usefull that link. As i wrote i allready install a used subframe from a 2003 MY. The only problem was that there was not support base for the electric handbrake. I solved with my old base and now is ok.
harvest14
Jun 7, 2015 12:24 AM
rayclark1
Mar 19, 2015 07:48 AM
Darrenmb
Dec 7, 2014 04:57 PM
alfredtv
Audio/Visual Electronics
Dec 10, 2012 01:21 PM
DpezXK8
Mar 2, 2010 12:26 AM
