Questions about my S type maint. history
Old Aug 2, 2008 | 06:16 PM
ccajun4real's Avatar
Default Questions about my S type maint. history
Alright here is my car's history. What else needs to be done and what can I expect to go out in the future? Thanks guys
I did not list regular interval maintenance, oil changes, or other minor things. My car has 130k on it.
17 APR 08
Timing chain
Chain tensioner
Chain guide
Chain tensioners
Timing covers seals
Camshaft gaskets
Spark plug seals
Centre seal
Oil filter
Water outlet seal
17 OCT 07
Window regulator
8 AUG 07
Vertical link replaced (LF)
Brake flush
14 DEC 2006
Front muffler pipe replaced
7 DEC 2006
Replaced front and rear rotors and pads
Replaced ball joint (RF)
23 AUG 2006
Power steering flush
8 FEB 2006
Replaced battery
10 OCT 2005
Coolant overflow tank replaced
3 JUN 2005
Replaced headlight master switch
3 MAY 2005
Replaced headlight stalk
4 JAN 2005
Replaced sway bar bushings
Adjusted shifter cable
21 DEC 2004
Replaced transmission
Replaced oil pan and timing cover gaskets
Replaced cam cover gaskets
Replaced ignition coils
3 SEPT 2004
Replaced passenger side rear window regulator
5 JUL 2004
Replaced oil switches
Replaced oil sending unit
27 MAY 2004
Shifter adjusted
11 FEB 2004
Replaced both valve cover gaskets
24 OCT 2003
Replaced drivers side rear window regulator
13 JUN 2002
Replaced thermostat
26 FEB 2001
Replace gas pedal
Old Aug 2, 2008 | 08:46 PM
badmojo's Avatar
Default RE: Questions about my S type maint. history
They forgot to replace the body! LOL. Man that's a lot of work. Did you buy it new?
Old Aug 2, 2008 | 09:09 PM
ORIGINAL: badmojo
No bought it last month for $5k. It had 129k miles on it. LOL Ya it struck me as alot of work also but evidently the owner had money because the receipts show well over $5k paid for after warranty ran out. He took it to the dealership for every little thing. There were 14 pages to the maint. record and the car was also a dealership car until April 08. The previous owner purchased it in April and had a domestic issue. That is when I happened along and negotiated what I believe to be an excellent deal. The car is very well taken care of and most believe it to be an 06 or 07 car when they see it.
Cajun
Old Aug 4, 2008 | 11:56 AM
KAZsam's Avatar
The only things left are the water pump,starter and a/c unit
good luck with it The car should run fine for you with almost eveything replaced.
stanjag
Dec 29, 2024 08:26 PM
GuernseyJag
Nov 8, 2017 10:40 AM
XK120Fan
XK120 XK140 XK150
Nov 30, 2015 02:09 AM
reedmtn
Aug 31, 2015 12:48 PM
Terrance Williams
Aug 26, 2015 11:50 AM
