Quick transmission question (2006 s-type 3.0)
Old Feb 21, 2016 | 06:47 PM
alexschmidt's Avatar
Default Quick transmission question (2006 s-type 3.0)
So I'm lazy, and the answer I'm looking for is probably on here but I don't feel like searching through dozens of pages.
Just got 2006 s-type with 6 speed auto. When the car is cold (under 30 F outside), first gear sort of slowly shifts to second. Not rough, just a half second where there is nothing. Is this a sign of the dreaded transmission lurch? (52,000 miles)
Old Feb 21, 2016 | 09:49 PM
Datsports's Avatar
don't think so sounds like sticky solenoid maybe give it a service.
when you say there is nothing does the revs flair like its dis engaged from drive ?
also have a read on this website its all about the dreaded lurch
Jaguar S-Type ZF Gearbox Lurch fault
Old Feb 22, 2016 | 01:16 PM
I read those 2 variants and I don't have any of that. Again I notice it once when the car is very cold, I just assume it is transmission fluids not being circulated yet?
Old Feb 22, 2016 | 01:26 PM
Jon89's Avatar
If your car is still running its factory fill of ATF, that fluid is now pushing ten years old and its friction modifiers have long since worn out. So it's time for an ATF drain-and-fill. That may be all you need to do to restore your ZF's shifting patterns to normal....
Old Feb 27, 2016 | 08:56 PM
99 kobra's Avatar
It did the trick for mine
Old Feb 29, 2016 | 08:59 AM
I feel so paranoid now. I cant enjoy driving my car when I have little issues that could turn into big issues. I feel like I am talking myself into believing I have the "dreaded transmission lurch". I guess Ill follow everyone's advice and have the fluids professionally changed. Thanks
Old Feb 29, 2016 | 10:15 AM
Jon89's Avatar
No reason to feel paranoid. Our S-Types are all getting a bit long in the tooth and certain components must be checked and sometimes refreshed or replaced. ATF is at the top of that list. So start with fresh ATF and see how your car responds. That may indeed be all you need to do in order to resolve your shifting issues....
Mercon SP is a much lower-cost alternative ATF to the factory fill of Lifeguard 6. Many of us are now running it in these ZF 6HP26 transmissions (which is what you have). Available at any Ford dealership for between $7 and $8 per quart. Do a bit of research and decide if you want to go with it....
Old Feb 29, 2016 | 07:27 PM
NBCat's Avatar
Here is some basic information on replacing the sump/filter and connector sleeve on the ZF 6HP26 gearbox.
When replacing the connector sleeve, it is critical that there be no static electrical discharge to any of the gearbox pins and that the sleeve maintains a 3mm gap with the housing.
Follow the procedure outlined in JTIS for filling the gearbox to the correct level at 45 - 50 C.
File Type: pdf
File Type: pdf
Old Feb 29, 2016 | 08:01 PM
I was quoted at $650 to replace fluids. 2 hours labor, 6 liters, and a $220 pan/filter.
Old Mar 1, 2016 | 08:22 AM
Jon89's Avatar
That's a relatively high quote. Check some of your local indie shops. Find one that will let you source your own parts and just charge you for their labor. You'll come out hundreds of dollars ahead....
Old Mar 1, 2016 | 02:16 PM
I understand it is "recommended" to only use zf lifeguard 6 fluids. I'm seeing it for ~$20. Do you know of a place that sells it cheaper, or what are the best alternatives to zf fluids? (In USA)
Edit: is a BMW zf6 filter/pan going to be comparable?
Old Mar 2, 2016 | 03:22 PM
So I now have an ever so slight knock sound when letting off the accelerator at under 15 mph.
Old Mar 4, 2016 | 04:54 PM
Datsports's Avatar
Check engine mounts . Both mine were broken when I purchest my car . It also had a small knock ! And I could see the bonnet/hood getting pushed up when I floored it , not ideal
Ignas Miknevicius
Jul 25, 2017 05:48 AM
calteg
Mar 7, 2016 03:12 PM
Vee
Feb 24, 2016 10:20 AM
64vette
Feb 21, 2016 07:11 PM
kelbymorgan
Feb 21, 2016 11:19 AM
