Qwiketz intake elbow thread including pics and dyno charts
Old Aug 12, 2012 | 11:46 AM
  #281
Cambo's Avatar
Sorry it's taken a while to get back to you, been a bit busy with the new arrival & i really wanted to have a closer look at the setup in the XJR before jumping in & buying the elbow.
Here are some more pics from the XJR;
Here looking from the side.
With the factory intake off you can really see the odd angle between the outlet of the airbox and the intake between the charge coolers.
The flexible bellows section on the factory intake compensates for the airbox outlet being angled forwards.
I looked again at the pictures of the STR's and the outlet of the airbox is seems to be at a different angle to the XJR.
Of course it's very hard to tell from just pictures online...but i guess it would be the same as goblue90's pic HERE?
And lastly the clearance of the intercooler coolant hoses underneath the intake elbow;
Is that the same mess as the STR? Because the OEM intake actually has a slot molded into it to allow one of the hoses to sit underneath.
Anyone have any comments before I bite the bullet? It'll fit?
Old Aug 12, 2012 | 07:52 PM
  #282
rasputin's Avatar
It will fit
Just cut it about a half inch on both sides, or .75 on the filter side and .25 on the intercooler side. Just a good cheap mod, very satisfied!
PM me if you want the other half of my stock breather tube that I cut, for a reasonable price, so you can retain your full uncut tube in case you ever want to go back to stock.
Old Aug 12, 2012 | 08:54 PM
  #283
bfsgross's Avatar
Yep, get the air intake elbow. The worst is to cut the connector bellows a bit here or there. Otherwise, it looks identical to the STR.
Old Aug 15, 2012 | 11:58 PM
  #284
qwiketz's Avatar
I think it should fit too! I'm going to ship this one out and based on your input, I may do a run for the xjr guys. We'll be waiting for your input as this is about an easy of a mod you can get for these cars that makes good power.
Old Aug 18, 2012 | 11:51 AM
  #285
bigd2005xjr's Avatar
Hello I was wondering if you still had any of the intake elbows? I just recently bought a 2005 XJR and I was hoping that this would fit my car. Any info would be great Thanks
Old Aug 20, 2012 | 01:36 PM
  #286
qwiketz's Avatar
Hi there. I will be shipping one out this week to a member that is fitting it on a xjr. So, we should know shortly if it will fit. I do have 2 left if I recall. We'll see how the test fitting goes and then go from there.
Old Aug 21, 2012 | 03:01 PM
  #287
Thank you very much, if the test fitting goes well then I will have to pick one up from you. Thanks again
Old Sep 4, 2012 | 03:57 AM
  #288
Cambo's Avatar
It arrived today, hope I can find some time on the weekend for a trial fit!
Old Sep 4, 2012 | 06:11 PM
  #289
bfsgross's Avatar
Looking forward to your XJR breathing easier and pounding out an additional 10-15 chp.
Old Sep 14, 2012 | 05:41 PM
  #290
qwiketz's Avatar
should be getting an update on this thread in the next day or two....
Old Sep 15, 2012 | 11:03 AM
  #291
Cambo's Avatar
Here are the pics you've been waiting for!
Took about 30 minutes to fit in the end.
Been out for a drive, no error codes, and a brand new whine from the blower;
I'm afraid my **** dyno isn't sensitive enough to pick up a 10HP increase, but based on the results from the STR's i'm confident there is an improvement, it certainly feels more responsive.
I bought a new breather hose so I wouldn't have to cut up my existing one.
Cost £22.29 incl shipping from the UK, www.davidmanners.co.uk took 2 weeks and that was with the part on backorder.
Now, about the installation, I feel there is a little room for improvement.
1. The hose clamps could be a little smaller on the tube itself, currently 3.5" could easily be 3.25" or even 3"
2. It would be nice to have a small bend at the airbox end, maybe 15° or so, just so it lines up a bit better.
3. I would also like it if the throttle end could be flared into an enlarged oval shape to better match the intake.
4. I would like it made from plastic
But hey, it fits, and it works, not bad!
Old Sep 15, 2012 | 01:55 PM
  #292
bfsgross's Avatar
Nice! There you go Cambo. Whine is intoxicating huh? Don't worry, there's 10+ more kitties under that lid. Periodic purging of adaptive learning helps to uncover them too.
Old Sep 15, 2012 | 02:45 PM
  #293
Cambo's Avatar
Here's another one.
Yes I suppose intoxicating is a word you might use...
Old Sep 16, 2012 | 12:05 PM
  #294
qwiketz's Avatar
Hey Cameron, glad to hear it worked out. If I ever do another run, I have a few ideas on how to correct the angle to the mass air sensor. All my experience says removing the silencers and smoothing out airflow is worth hp. Eaton supercharged applications in general are very inlet restriction sensitive.
Old Sep 16, 2012 | 08:33 PM
  #295
Robert Page's Avatar
This mod looks good I would be interested when more are available for the XJR. What are you charging for the kit? Cambo what exhaust set up are you running? Are you still getting no error codes?
Old Sep 17, 2012 | 01:00 AM
  #296
Cambo's Avatar
My car is mechanically stock, for now at least, except for the intake tube.
I was worried about P0171 + P0174 which is both banks too lean = vacuum leak.
But it's all tight as a nut. A very effective mod for the money + time involved.
Old Sep 17, 2012 | 07:20 AM
  #297
Michael Star's Avatar
As long as everything is buttoned up, you shouldn't have any issues with running lean. Did you reset your ecu after you installed it?
Old Sep 17, 2012 | 12:15 PM
  #298
qwiketz's Avatar
Hey guys. The cost is $210 shipped in the US. I have 2 of them left and they fit the STR and the XJR.
Old Sep 18, 2012 | 04:50 PM
  #299
What is involved with resetting tHe ECU, and why do you do it?
Old Sep 19, 2012 | 05:05 AM
  #300
Cambo's Avatar
To reset the engine adaptations, you need to disconnect the battery (both cables) for about 10mins, and then touch both cables together. This drains the capacitors that maintain the "memory" in the ECU.
Why? Well when the engine conditions change, i.e. more airflow from the intake elbow, then the ECU has to learn these new conditions and adjust accordingly. Re-setting the adaptations speeds up the learning process.
I haven't done it yet because I can't be bothered re-programming the windows and the radio stations...again...
The ECU will eventually catch up....
