Rapid Beeps / Click from J-Gate
Old Oct 18, 2025 | 04:57 PM
ampiko's Avatar
Default Rapid Beeps / Click from J-Gate
Hello,
Yesterday when I turned off the ignition I heard rapid fire beeps like you hear if you turn off the ignition while the in Drive position or if there is an issue with the emergency parking brake.
Also, when i open the driver door, sit and close it, i hear the same beeps which last for 5-7 seconds.
I also noticed a Click from the J-Gate when the brakes are pressed while in P. Normally i would hear the click from the outside.
No code or warning messages on the Dash. Thank you
Old Oct 19, 2025 | 04:01 AM
Peter_of_Australia's Avatar
I saw your question already shortly after you posted, but hoped, that someone, who would have a better answer than me would answer you...
But as there is still no other reply...:
You symptoms would suggest that the switch, which gives positive feedback to the system that the gear lever is in position P is defective or the wiring to it or the connector to it (I am not absolutely sure, that there is a switch like that, but I simply assume that there is.
But This would also mean, that your system does not know, that you are in "P", and consequently it should not be possible to start the car... - unless the system thibnks that nit is in position "N".
And if it does not start in P, it should start in N...
Old Oct 19, 2025 | 11:55 AM
ampiko's Avatar
Originally Posted by Peter_of_Australia
I , that your system does not know, that you are in "P", and consequently it should not be possible to start the car... - unless the system thibnks that nit is in position "N".
Thank you for initiating the discussion. Actually the car does start a normal in the P position. Then drives normally.
Old Jan 13, 2026 | 09:26 PM
PaulVC's Avatar
So this was years ago, so please forgive me if my memory is not too well, but I believe I had the same issue happen to me before like 10 years ago with my S-type. What happened was the two bolts referenced in this thread below were coming loose. That fixed my issue. Hopefully it is the same thing you are experiencing.
Gear Cable Control Bolt - Jaguar Forums - Jaguar Enthusiasts Forum
Old Jan 15, 2026 | 01:44 PM
clubairth1's Avatar
Community Influencer
Very good point about those 2 bolts! That thread has a nice picture of what your looking for.
Easy to check but you have to get under the car.
Old Jan 15, 2026 | 05:24 PM
ampiko's Avatar
The issue disappeared. Incidentally, I had the driver's door open as i was checking for parking lines while the engine was running. I switched off the ignition and there was no beeping afterwards. Something must be bonkers.
Old Jan 15, 2026 | 06:32 PM
NBCat's Avatar
Start with available battery voltage. If a voltmeter indicates less than 12.6 volts with the ignition off for over half an hour, the battery may be the cause of random faults.
Gerald Clark
May 17, 2024 01:05 AM
inertian
Mar 21, 2022 09:46 AM
auburn2
May 19, 2020 08:15 AM
les9187
Aug 7, 2019 11:27 AM
captbob73
Dec 8, 2013 02:49 PM
