Re-flash for TC
Guest
Posts: n/a
Ok. I have the "lurch" in my 03 STR. I called a dealer asking how much a re-flash would be for the fix and was quoted $165. Does that sound like a fair price? The "lurch" doesnt really bother me, if I were to leave it alone will it mess up the transmission? Thanks.
Steve
Steve
the dealer clear's the shift adaptations and reflashes the tcm with coded access which means the laptop will give a code then you call jag to verify the code then they give you a code.. then it get 's reflashed for the specific problem..which updates the tcm software.. then the tech must drive the vehicle and relearn the tranmission drive cycle's and shift patterns .. certain procedure that must be done.. to get it to shift perfectly.. they will charge you 1-1.5 hrs which is a decent time..
