Rear brake caliper sticking
Old Oct 16, 2011 | 07:50 PM
Bob Smith's Avatar
Default Rear brake caliper sticking
Hey gang,
The right rear caliper on my 05 S-type seems to be sticking. At first I thought the parking brake was at fault, but after disconnecting the EPB cable I still have the same issue. I had changed the rear pads & rotors not long ago and noticed that the right pads were far more worn than the left, so this issue seems to have been brewing for a little while.
Has anyone had luck re-building these themselves (any tricks or tips on disassembling, etc.?)? Any good non-dealer sources for new calipers?
I guess I should also check for a collapsed flexible brake hose too as sometimes those will allow fluid out but not back in (keeping pressure on the caliper).
Thanks in advance,
Bob
Old Oct 16, 2011 | 08:04 PM
Mikey's Avatar
Were the pins that the caliper slides on free and easy to move?
Old Oct 17, 2011 | 01:46 AM
JagV8's Avatar
Probably they're seized
But may free up
Old Oct 17, 2011 | 08:35 AM
Bob Smith's Avatar
Thanks guys.... good point on the pins. I kind of forgot about that aspect of it... I'll check the movement of those tonight. I pulled the caliper off late yesterday but hadn't had a chance to give it a good look yet.
Old Oct 17, 2011 | 06:32 PM
Bob Smith's Avatar
Good call on the pins Mikey. One of them is seized up bigger than Dallas... I couldn't even budge it with a drift and hammer with the caliper in a vise. Looks like I'll try one of those re-manufactured calipers from Napa for ~$150.
This is probably one of those things everyone should check when changing pads... make sure the pins are well greased and the boots that cover them are on tight and not torn. I could see how a torn or improperly seated boot would let all sorts of crap into the pins and contribute to such a failure.
Thanks again guys,
Bob
Old Oct 17, 2011 | 07:06 PM
Mikey's Avatar
Glad you found what was wrong, even though it will cost a bit to fix.
Old Oct 18, 2011 | 07:23 AM
JagV8's Avatar
My mate (who's arguably a bit over-keen) regreases the pins on each service.
(I know!)
Like him I take the wheels off at each service, check them for damage etc and check all the suspension, brake pipes, wires, etc as best I can.
H20boy
Dec 24, 2024 03:23 PM
mbergen
Oct 23, 2019 10:26 PM
PMKimpton
Aug 3, 2019 08:22 PM
philwarner
Sep 5, 2015 10:05 AM
mikelibera
XJ40 ( XJ81 )
Sep 4, 2015 05:17 PM
