Rear Discs
Old Jul 17, 2016 | 06:35 PM
Whale's Avatar
Default Rear Discs
I recently had success with fitting brake calipers from a Ford Mondeo to my 2001 S-Type 4.0, but does anyone know of a Ford (Australia) compatible disc as mine (rear) are to thin to machine?
Old Jul 17, 2016 | 08:06 PM
Mikey's Avatar
The correct rotors are available at any car parts store.
Old Jul 17, 2016 | 08:59 PM
Whale's Avatar
Thanks again - but as soon as you mention "Jaguar" down here the part price doubles (at least), but as many Ford / Lincoln parts are compatible I try to source those as a much cheaper option.
Old Jul 18, 2016 | 10:26 AM
Mikey's Avatar
Just for fun, have you actually asked for prices and compared them to a 'mainstream car'?
You might be surprised.
Old Jul 18, 2016 | 10:30 PM
Whale's Avatar
Mikey - Yes I have, where the most recent was the water pump that was quoted at AD$260 and I got an identical Ford part for AUD$131.
______________
2001 S-Type 4.0R
Old Jul 19, 2016 | 11:08 AM
Jumpin' Jag Flash's Avatar
From: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
Check the Ford Thunderbird and Lincoln LS parts catalogs as some of their parts are interchangeable with the 2001 S-type.
But you can easily find the original Jag part number in JEPC, then go to an online retailer like RockAuto.com, AutoPartsWay.com, PartsGeek.com, etc and do a search on their website by the Jag part number. That will crossreference to the list of aftermarket brands/part# that they sell that are compatible with your car. They may not ship to Australia, but you will see that there is no special pricing because the part is compatible with a Jaguar. If you want to buy the parts locally, use the brand-name and part number info you got online as your starting point.
Last edited by Jumpin' Jag Flash; Jul 19, 2016 at 09:13 PM. Reason: Corrected JEPC reference
Old Jul 19, 2016 | 11:24 AM
Mikey's Avatar
I looked at several OZ-based on-line car part vendors and found that the correct rotors were not more expensive than other cars, just like it is here or in the US.
Old Jul 19, 2016 | 07:19 PM
mastersid's Avatar
Whale , FYI
Unless you want OEM parts , you can buy after market rotors to suit your Jag ( 288 mm )
for around 70.00 dollars each , in Sydney .
Ford Mondeo 95 on rotors are 253 mm and from 09 on 302 mm in diameter ( Aus ).
The rear calipers are the same as they are the BOSCH brand calipers and the rear pads are also the same .
Old Jul 20, 2016 | 06:40 AM
JagV8's Avatar
______________
2001 S-Type 4.0R
Why the R ? The 4.0 didn't have an R did it?
Old Jul 20, 2016 | 03:38 PM
ZenFly's Avatar
Have you looked here ? 2001 S-Type rear brake disc | eBay
Old Jul 20, 2016 | 10:32 PM
Whale's Avatar
It sure did, the "R" is a supercharged version of the 4.2L V8 (the "STR").
Old Jul 21, 2016 | 12:14 AM
JagV8's Avatar
Yes but your signature showed 4.0 and there was no 4.0 STR was there?
Pilotman11
May 11, 2016 03:40 AM
Anonday
May 5, 2016 04:56 PM
tonyk1242
Apr 29, 2016 12:32 PM
Mac Allan
Apr 25, 2016 11:40 PM
zigzewel
Apr 22, 2016 10:25 PM
