Rear passenger door problem
Old Jul 19, 2012 | 10:28 PM
totalimmortal363's Avatar
Default Rear passenger door problem
It feels like the door handle is hard to pull, like something is no longer lubricated inside the latch mechanism and is dragging. I'm afraid to do damage to something by using the door.
How should I remedy this?
Old Jul 20, 2012 | 09:04 AM
Jon89's Avatar
You'll probably need to remove the interior door panel and have a good look at your door latch mechanism in order to determine what may be causing the problem. It could be anything from misalignment to broken components. I believe that Rick (joycesjag) had to replace some rear door latch parts recently on his 2005 S-Type. If he's around today, I'm sure he'll chime in here with more details. You may also want to search the forum using the key words "door latch repair" or something similar....
Old Jul 20, 2012 | 09:38 AM
GT42R's Avatar
Just to clarify, you are referring to the door pull handle being difficult to 'pull' and release the latch in order to open the door, correct?
You are not referring to the door being difficult to swing open, as if the hinges are sticking?
Old Jul 20, 2012 | 09:27 PM
Correct, the handle is hard to pull. Once pulled the door swings freely.
Old Jul 20, 2012 | 09:56 PM
joycesjag's Avatar
You may want to try lifting the exterior door handle and spraying some lube into the upper recess of the door handle. You may have to do it a couple of times.
You can refer to the link for what you are going to be dealing with.
Have fun!!!
https://www.jaguarforums.com/forum/s...ics-faq-65657/
BrentGardner
29
Dec 16, 2024 12:13 AM
hafren
Aug 30, 2023 03:42 PM
MarathonJohn
Sep 3, 2015 07:59 PM
Aranon
Sep 3, 2015 07:56 PM
frankc
Sep 1, 2015 04:41 AM
