Rear view mirror , 2000 S type advice
Old Jun 15, 2024 | 12:16 AM
osyris's Avatar
Default SOLVED Rear view mirror , 2000 S type advice
I have a 2000 S type v6, and need to remove the mirror, however I note there are different versions on different cars throughout the years.
See pic below, it has a very small setup on the windscreen, do I push upwards or downwards to remove this, it seems absolutely tight on the windscreen?
Where is the connect to this mirror, I looked under the overhead console once removed, nothing there.
I'm going to install a new mirror and wired it up. I just did this on my x308.
Peter
Old Jun 15, 2024 | 04:59 AM
osyris's Avatar
Solved
Here's the answer.... I searched Ford forums thinking it's a ford part and was right.
One uses an Allan key , takes 5 seconds , mirror shifts upwards parallel to windscreen
Makes sure you disconnect the connector plug in the back of the mirror, and move aside the long tubing cover...apply some silicon to the bracket first for lubrication.
Peter
snooktarpon
Apr 8, 2020 03:34 PM
jimforrest (uk)
Mar 5, 2015 01:23 PM
NikolaiDiqnov
Dec 15, 2014 02:58 PM
soonerpride316
Nov 6, 2010 06:52 AM
ohsigmachi
Oct 11, 2010 04:54 PM
