recovery tank replace
Old Sep 13, 2011 | 05:11 PM
stanstinn's Avatar
Default recovery tank replace
Does any one know how the (quick release) at the bottom of the resevoir of a 4.2 comes off and how is the best way
Old Sep 13, 2011 | 06:53 PM
aholbro1's Avatar
"Quickly!"
sorry, couldn't resist...lemme go take a pic if I still have the tank out in the shop..think that joint is the same on the 3.0L...pull the clip (Don't lose It!!!) then wiggle the hose gently and it should pop right out (with a gush)
Old Sep 13, 2011 | 07:25 PM
aholbro1's Avatar
Dang!!!
What was I thinking?!? You are doing a replace..you have nice view of tank-part of the joint.....
Well....nearly burned myself trying to get a pic of the wire clip on the connector - wife just recently brought the Stype home...but you disengage it - you can see the groove on the tank nipple it is riding in....pull it out and have a magnet ready to pluck it off the undertray - it SHOULD stay with the hose coupling..but the best-laid-plans, and all that.....then there is nothing to hold the connection together but the years of accumulated dust and crud. Wiggle and turn gently...you don't really care if you break the tank nipple, but you don't want to damage the hose-connector! Tip: After you fit the new tank, and insert the clip....do the same gentle wiggling/twisting/working at the joint to ensure it is properly engaged before refilling the reservoir.
If 4.2L way different..sorry, this is all useless to you
Tank groove:
Forcedair1
Sep 8, 2025 01:57 PM
cissdm
May 3, 2016 06:02 AM
al_roethlisberger
Sep 11, 2015 10:04 PM
alpecsa
Sep 7, 2015 11:55 AM
KarimPA
Sep 3, 2015 07:32 PM
