Removing transmission
Old Jan 8, 2012 | 03:59 AM
Plum's Avatar
Default Removing transmission
I am attempting to remove a transmission from a parts car.
I have removed the bolts that secure the tranny to the engine. Removed the drive shaft as well.
I have two jacks underneath the transmission to ensure it would not fall and damage, though it appears to be stuck.
I have attempted (quite delacatly) to use a screw driver and hammer to dislodge the transmission from the engine.
Any tips?
I have not taken off the starter as this looks like shear hell... Do I need to?
Old Jan 8, 2012 | 04:50 AM
Plum's Avatar
Sorry - 2001 5r55n
Old Jan 8, 2012 | 07:08 AM
joycesjag's Avatar
1) Are you sure you have ALL the bellhousing bolts out?
2) Is the engine supported?
3) if all of the above is done, according to alldatadiy it should slide out.
Becareful of the torque converter not falling on you.
Old Jan 8, 2012 | 08:16 AM
police666's Avatar
pdf from jtis auto box removal.
Hope this helps
File Type: pdf
Old Jan 11, 2012 | 11:03 AM
Plum's Avatar
Thank you!
I have removed the starter now, and attempting to remove the torque converter.
From my understanding, there are 4 bolts, in which to access the 4 bolts for removal, I must turn the engine.
I have attempted to turn via the crank case pulley, and drive shaft, to no avail.
The parts car had engine problems in that the engine ran out of oil, and is seized as per the previous owner. My attempts to roll over seem to confirm.
Any suggestions or corrections to my methods?
Old Jan 11, 2012 | 11:07 AM
police666's Avatar
can you not just rotate the torque converter ?
Old Jan 11, 2012 | 12:14 PM
Plum's Avatar
Apparently the torque converter need not be removed.
I was given a tip from a ford mechanic stating that these tranny's sometimes stick at the top - 10 & 2
There is some sort of balancing screw or...
Anyways
Good news: it is removed
Bad news: I cracked a chunk of the tranny while using a hammer.
Junk or can I somehow fix?
Now I know why I am not a mechanic.
Old Jan 11, 2012 | 12:19 PM
joycesjag's Avatar
I had a bell housing fixed.
It was on a 1984 Trans Am, 5 speed. I blew the clutch disk apart and shattered the "bell housing" the welders fixed that.
Not very expensive.
Old Jan 11, 2012 | 12:20 PM
tbird6's Avatar
Well you learned a good lesson here. If you don't know what you are doing please stop.
You now have a junk transmission.
Old Jan 11, 2012 | 02:00 PM
police666's Avatar
what part of the gearbox did you break, can you post a pic ?
Old Jan 13, 2012 | 09:39 PM
Plum's Avatar
We're fine, thankfully. I thought like t-bird, and cursed beyond belief.
Yes - I might not be an expert, but this is how one learns.
I have put 90k miles on my girl, and she has tolerated me well.
Old Jan 13, 2012 | 09:46 PM
BlackX300VDP's Avatar
If you have a V6 (i didn't look up specs or anything for u) there is one neatly placed bolt in a depression in the bellhousing on the drivers side. The other part (and what i think might be why it was stuck on) is the fact that the dowels that lines it all up were steel and the engine block and trans case are aluminum. corrosion set in on those cars the day it drove off the lot. We mangled many, many, transmissions getting them out. Even the newer ZF 6spd boxes do the same. As far as the TC, if the engine doesn't spin, then the only way I know of getting them out is by removing the engine and crankshaft. V6 engines had four nuts or bolts, V8 engines had 8 nuts.
Where did you break it?
Old Jan 14, 2012 | 02:06 PM
Plum's Avatar
Right on the edge of the bell housing, though it is no cause for concern, thankfully.
aholbro1
Dec 29, 2024 06:46 PM
tomsjag
Jun 10, 2023 10:02 AM
Jandreu
Jun 30, 2022 03:10 PM
1LowCat
Feb 23, 2016 07:19 AM
mrplow58
Sep 9, 2015 11:27 AM
