Replaced Front Hub Wheelbearing
Old Jan 3, 2014 | 09:34 AM
bluebossa's Avatar
Default Replaced Front Hub Wheelbearing
Uploaded a few pictures to help others. 2000 S Type had play on Nearside.
Easy ish job - took around 1 hour 30 mins with just a socket set, a Jack and an Axle stand.
1- First Jack Car secure - Axle Stands and lower
2- Remove 2 Bolts securing Disk and Caliper to Stub - 15mm
3- Tie Disk and Caliper up and out of the way
3- Remove 4 Bolts behind Hub - need a long bar and 15mm
4- Remove inner Wheel arch splash guard - 3 plastic connectors
5- Disconnect ABS sensor
6- Clean mounting surfaces and copper grease
7- Fit new Hub - route cable and re-connect
8- Torque up Bolts - 90Nm
Album in photos Jaguar Forums - Jaguar Enthusiasts Forum - bluebossa's Album: Front Wheel Hub Bearing Replacement
philwarner
Dec 6, 2021 07:13 AM
Doberman_Fan
22
Dec 24, 2019 06:21 AM
Paradigm
Jun 15, 2019 05:59 AM
Fraser Mitchell
Oct 1, 2015 04:06 AM
aquifer
Aug 29, 2015 04:54 PM
