replacement fuel pumps 2005 s type R
Subscribe
Jun 12, 2024 | 04:34 PM
filled up my just purchased 2005 s type r and a quarter of the tank over flowed at the flange at the top of the fuel pump should I replace with used or after market pumps and if so what brand?
thanks
Chris
Reply 0
Jun 14, 2024 | 01:39 AM
Quote: filled up my just purchased 2005 s type r and a quarter of the tank over flowed at the flange at the top of the fuel pump should.
thanks
Chris
The fuel pump cap and connections usually don't leak.
I would investigate further and find out what and where the leak issue is!
depending on your vin sender/fuel pump cap etc.
https://parts.jaguarlandroverclassic.../brand/jaguar/
The cap seal.?
Cap damaged?
Cap not secured?
The fuel pipe connectors.?
Has someone been in there before and not seated/secured the top cap correctly.
Etc.
Then you can take it from there with what is required and where/which side etc.
Reply 2
Jun 14, 2024 | 09:41 AM
Not sure of the exact source of the leak, but this thread may be of some interest for dealing with the metal band clamp:
https://www.jaguarforums.com/forum/s...l-band-221643/
Reply 0
Jun 15, 2024 | 02:17 PM
this is the one year only california pump they’re known for doing this.
XR848122
Reply 1
Subscribe
Currently Active Users (1)
