restricted performance
Old Sep 29, 2008 | 08:48 PM
v8stype's Avatar
Default restricted performance
hey guys i need some advice i get a restricted performance light when im at a stop light for longer than a minute and goes away once i go past like 40mph i checked for vacuum leaks and cleaned my maf and nothing.i just have a k&n drop in filter.
Old Sep 30, 2008 | 08:23 AM
racerx82's Avatar
Default RE: restricted performance
how many miles?
Old Sep 30, 2008 | 10:06 AM
Brutal's Avatar
MORE LIKE GO GET CODES PULLED TO SEE WHAT THE ECU SEES OR SAW, AND HOPE THAT ITS NOT SOMETHING THAT IS NOT RETAINED UNLESS IT IS ACTIVILY IN RP, AND IT MAY BE A JAG SPEC CODE WHICH MEENS GO TO THE DEALER IF DOESNT SHOW UP AT AN AUTOPARTS STORE WHEN YOU HAVE THEM READ WITH A GENERIC SCANNER
Old Sep 30, 2008 | 04:50 PM
whiteSTR's Avatar
Ok, I had a factory Jag filter in my R that was covered with sand, dragon flys, bugs, leaves, everything imaginable... I got annoyed with the dirty filter one day and went to the store and bought whatever they had thinking it would be better.. It was a purolator (which i know is a garbage filters) but better than a dirty one right? So i put it in and for the next 4 days got restricted performance at every light I was at then when I started driving again it and got over 30 it went off... So my problem solving abilities told me to reverse anything I had recently cahaged.. sure enough I put the dirty, bug covered factory filter back in and have not had a problem since... for over 2 months..
Our cars are very picky.. sometimes something as little as a filter can screw them up.. try an OEM jag filter and see what happens... (you will probably never see restricted performance again) also make sure the oil from your k&n didn't cook your MAF sensor.. or at least clean the sensor..
Old Sep 30, 2008 | 04:57 PM
Brutal's Avatar
WELL IF YOU HAVE A P0171.P0174 IT CAN CAUSE RESTRICTED PERF IF LEAN ENOUGH, BUT OF ALL THE K&N FILTER IVE NEVER SEEN ONE CAUSE A FAULT IN A JAG, BUT HAVE SEEN TECHS AND CUSTOMERS NOT SNAP THE BACK SIDE DOWN CORRECTLY THAT HAS THE 4 TABS THAT GOES INTO THE SLOTS AND OR LEAVE THE AIR INTAKE DUCTS LOOSE. MATTER OF FACT, THE FACTORY LEAVES THESE LOOSE TOO.....FIND IT OCCASIONALY ON 1ST SERVICES, OR CHECK ENGINE LIGHTS CHECKS
Old Oct 2, 2008 | 01:15 PM
v8stype's Avatar
thanks for the advice guys,before checking for codes or buying another filter i took my airbox out and found my filter was really dirty so i used the k&n recharge kit and to be sure i didren't over oil it i blow dryed it and then vacuum the filter and haven't seen a rp light since.
Delta66
Oct 4, 2015 05:40 PM
Johncy2000
Oct 2, 2015 01:05 AM
1100me
Oct 1, 2015 11:49 PM
Glenn Barickman
Oct 1, 2015 04:09 PM
