retarded timing advise ! what Now .
Old Jul 27, 2020 | 07:06 AM
  #101
joycesjag's Avatar
Any update?
Old Jul 27, 2020 | 08:38 AM
  #102
jaimster's Avatar
oh yea ! thanks for asking Joycesjag..
so ended up replacing the upstreams air to fule sensors with OEM denso also I got an old OEM denso MAF sensor from amazon for just 25 bucks ,, soon after replacing the MAF sensor i could feel ant read the difference mostly staying around 5.0 ... at idle and then i did replaced the (upstreams) air to fuel sensors also I got the original downstream sensors there ..also I removed and cleaned the MAP sensor placed it back ..
also did another SMOKE TEST AND EXHAUST PRESSURE TEST ( new tool PRESSURE GAGE TOOL I got from amazon ) FOUND NO LEAKS on smoke test and exhaust test - gauge pressure stays a bit past "0" on ALL four sensors inlet/outlet at CATS.. ALTHOUGHT WHEN measuring temperature with "infrared gun " at inlets / outlets at CATS BANK 2 probably around 30 degrees THE WORST BANK 1 around 45 degrees difference ..
I m thinking CATS may be contaminated previously car had blown head gaskets .. with past owner .
outcome NOW : after a week - CAR still idles rough when COLD START after warm up so much better.. so car has PENDING codes ONLY still has codes on " multiple misfires and bank 2 running lean " NO CURRENT CODES AT ALL AFTER A WEEK OF driving it .
ANOTHER ISSUE .. noticed it a couple OF TIMES when filling up with gas at full tank - Car leaks gas - looks like is coming from top of tank , it leaked around a half gallon last time i filled up with fuel. wondering if that is related to he ALWAYS THERE LTFT ON BANK2 HIGH 16.5 at idle it goes down to bellow 5.0 at throttle..
Old Jul 27, 2020 | 09:34 AM
  #103
Aarcuda's Avatar
hey buddy! Been offline until yesterday or so. Saw your pm. Maybe I can help. Once I have a minute. I have another s type that some tore the valve covers off so maybe we can run some visual checks on timing
Old Jul 27, 2020 | 02:48 PM
  #104
jaimster's Avatar
NP. Aarcuda ..
I m at work and NOT driving the car today .. when i get home later today i can let you know .. let me know what to look for or where to start ?
like i stated : LTFT BANK 2 ALWAYS HIGH .around 16.0 at idle than it goes way lower . CATS temp seem to be to close to each other , I believe OUTLET supposse to be warmer at least 100 degrees than
INLET for what i understand !!
fuel leak another issue too. appreciate your help ..
Old Jul 27, 2020 | 03:58 PM
  #105
Paul792's Avatar
Default Recall on Gas Tanl Seals
Hi Jaimster
There is a recall for gas tank seals on your model. I wonder whether this has got something to do with your rich fuel mixture as a leak may change the mix of fuel and air ratio.
https://auto-recalls.justia.com/jaguar/s-type/2005/06v418000/index.html
CONTACT JAGUAR AT 1-800-452-4827
Old Jul 27, 2020 | 05:55 PM
  #106
jaimster's Avatar
WOW ! Paul .. appreciate it i will contact them , Yo never know that fuel leak maybe related emission leak / too lean on BANK 2 even thought I m NOT getting any codes on that !!
Old Jul 27, 2020 | 07:28 PM
  #107
Aarcuda's Avatar
I wont be able to do much tonight. I JUST finished replacing the ac compressor and im beat. It was a nightmare but look (and its 88 degrees outside)!
Old Jul 27, 2020 | 08:02 PM
  #108
scottjh9's Avatar
t
You were silent again for a bit...you ok..man, when you get finished with that car it will be showroom....great job on the ac....bet it would be 2 grand at a shop....getting the damn belt on is a bear too
Old Jul 28, 2020 | 08:42 AM
  #109
jaimster's Avatar
so i called Jaguar corporate and dealer on the RECALL it turns out according to their record - RECALL was taken care back in 2007 .. they wont do it AGAIN. .. SO much for that .. i would never buy a new car from them.
on another note: this morning got bunch of codes CURRENT ones , misfires cylinder 1,3,5, and rate above limit one NO LEAN CODE ON BANK 2 any more . even thought LTFT BANK 2 IS HIGH 18.0 AS OF THIS MORNING !!
its kind of frustrating COLD START idles kind of rough.. ONCE it warms up runs pretty dam good..
Glad to hear you got a/c going man.. heat and huminity is brutal here in TEXAS stay COOL..
Old Jul 28, 2020 | 09:00 AM
  #110
JagV8's Avatar
None of that sounds like it could be the fuel tank anyway.
I don't understand why you would be mad that Jaguar would not do again something which has been done once and does not need doing again.
Old Jul 28, 2020 | 09:10 AM
  #111
jaimster's Avatar
they wouldn't give any details on what they Did. at all !! just that it was done NOT upset particularly at Jaguar ,, other Dearlers are the same way ! they dont want to help you unless you pay a fee,, that's what they asked for 179.00 for diagnosis fee
Old Jul 28, 2020 | 10:14 AM
  #112
joycesjag's Avatar
Just for cold poops and giggles. Have you ever thoroughly inspected the intake tube and resonator box for cracks or holes? Look at this thread post #32.
https://www.jaguarforums.com/forum/s...-198690/page2/
This will not have anything to do with the gas spillage but, might help with codes.
Old Jul 28, 2020 | 11:10 AM
  #113
jaimster's Avatar
oh yea ! I did that a while back ,, Maybe I should inspect it again...
Old Jul 28, 2020 | 11:20 AM
  #114
Aarcuda's Avatar
Have you pulled all 8 plugs yet? I need to see clear photos of the electrodes and what cylinder each plug was from.
As for the head work, did they just repair the one head? or both? If they milled one head and or i you used a non stock head gasket, the cylinder pressures wont be equal bank to bank and I believe that throws the ECU into kaniption fits as it throws an imbalance into the system.
Old Jul 28, 2020 | 11:50 AM
  #115
jaimster's Avatar
they milled both heads .. last time i did a compression test BANK 1 was around 175, 180 ,180 BANK 2 around 200 , 205,195 i will have to verify those numbers something like that , I posted the results a while back.
I got the head gasket from Rockauto.com !! i can take it apart friday again and post photos of all 6 plugs corresponding to cylinders ?
another question still .. what should the fuel pressure be at idle and open wide throttle for a 2005 s type 3.0 ? I know this model has NO shradder valve to mechanicly check fuel pressure , fuel pressure sensor was also replaced recently NO change ..
Old Jul 28, 2020 | 12:28 PM
  #116
NBCat's Avatar
Here are the fuel system specifications for the X200/X202. Use a smart phone with the Torque app connected via a Bluetooth interface to read fuel pressures.
Old Jul 28, 2020 | 03:04 PM
  #117
jaimster's Avatar
HA ! why am I reading 381.. 384 Kpa at idle then goes lower at open throttle.. I have gotten the same reading with two different fuel pressure sensors ???
Old Jul 28, 2020 | 03:07 PM
  #118
NBCat's Avatar
Perhaps this is already buried somewhere in this thread, but has the fuel filter been replaced? If so, inconsistent fuel pressure can be caused by a failing or weak pump or restriction in the fuel lines.
Old Jul 28, 2020 | 06:01 PM
  #119
jaimster's Avatar
thanks NBCat,
from I m getting the fuel pressure is way too high most of the time is at 381 kpa ... how Do I accurately test the pump or any suggestions ? or should I just replace the fuel pump and are there two sending units ?
Old Jul 28, 2020 | 07:56 PM
  #120
Aarcuda's Avatar
thanks NBCat,
this could be part of your issue. High pressure forces more fuel in causing a rich condition. How are you measuring it? .
