S type 2.5L v6 04 trans problems
Old Jun 11, 2024 | 05:33 AM
ffitrananda's Avatar
Default S type 2.5L v6 04 trans problems
Hi, the car have been out of commission for a while because it won't go forward in Drive, trans in question is a 6hp26 it will go into reverse well enough, but if i shift it into drive, the car jumps backwards like it's trying to get into reverse and can't go forward or backwards, drive wheels locked up, below i attach a short video of the symptom,
If anyone has had experience with this, or got any suggestions on what to check it would be really helpful. Thanks
File Type: mov
Old Jun 11, 2024 | 01:54 PM
JagV8's Avatar
Check the 2 (8mm hex?) bolts (under car) holding the shift cable to the trans are present and snugged up.
May need to check trans fluid level.
If all OK, may need trans diagnosis...
Childeric12
Jun 14, 2023 10:08 PM
2jag
Feb 5, 2013 04:23 PM
2jag
Jan 22, 2013 11:21 AM
Zippy8792
Jun 4, 2012 08:40 AM
Audie1966
Mar 3, 2011 05:03 PM
