s type 3.0 auto brakes stuck on !!
Old Nov 14, 2012 | 08:28 AM
odollybird's Avatar
Default s type 3.0 auto brakes stuck on !!
i have an s type 3.0 auto and have been useing the car everyday, got in it today put it in reverse and pressed the electronic handbrake button and the car didn't move at all so put my foot on the accellorater to make it move and it was very stiff and the car moved but was very stiff to move .... now there was no warning lights on on the dashboard to say that there was a fault but the brake lights on the outside was on ... i got back in the car and put my foot under the brake pedal to lift it up and the car moved as normal so i am wondering if it is just something wrong with the pedal perhaps maybe a spring broke or could it be something more technical ?
Old Nov 14, 2012 | 08:37 AM
abonano's Avatar
Odollybird - Proper protocol would be to introduce yourself in the new members section. That link is below:
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
Not an expert with the EPB system - but from what I undertsand the EPB not disengaging is a common fault - please also mention the model year for your S Type as that would be helpful - Thanks...
Old Nov 14, 2012 | 09:13 AM
odollybird's Avatar
so sorry, my name is Emma and have owned the s type 3.0 auto sport for a year now ....it's a 2003 model
Old Nov 14, 2012 | 09:39 AM
Mikey's Avatar
Hi Emma- welcome
It shouldn't be necessary to touch the parking brake handle to apply or release the EPB during normal operation. It's done automatically, however it doesn't sound like yours is malfunctioning in this case.
Obviously, it shouldn't be necessary to lift the foot brake pedal either and it's not normal that the brakes lights stay on and the car drags with the pedal released. You might be right that it's a return spring that's given way or it might be something more complex with either the booster or master cylinder becoming jammed. I don't suggest driving the car until it's properly inspected and fixed.
Perhaps others have had similar problems and can give more precise help.
Mike
Old Nov 14, 2012 | 10:04 AM
odollybird's Avatar
hubby's just had a quick look and he say's the problem is that the foot brake pedal is down .... so could it be the spring that is broke ?
Old Nov 14, 2012 | 10:35 AM
Emma,
I've moved your tech question from the UK Region section to the S-Type section.
This will get it seen by more members around the World with the same model.
Old Nov 14, 2012 | 10:39 AM
Mikey's Avatar
Emma-
I've responded to your initial question in the S-type section. It's not the EPB that causing problem, it's the main service brake.
stanjag
Dec 29, 2024 08:26 PM
ClassiXtype
Oct 22, 2023 05:29 AM
tonimccloud
Sep 3, 2015 07:58 PM
Rusty1952
Sep 1, 2015 05:45 AM
EastFalk
Aug 29, 2015 08:22 PM
