S type Air Blend door sound behind cluster
Old Mar 7, 2023 | 09:25 AM
elDariusVargas's Avatar
Default S type Air Blend door sound behind cluster
Hi!
I've read a lot of topics about this sound behind the cluster (LHD car), and they all suggest it's some liquid bubbling in the aircon system...
It starts after aprox 30 seconds after i remove key from ignition. i dont even use the AC for this to happen.
My defrost works.
I am uploading a video on YT in hopes someone recognizes it and can point me do the blend motor so i dont have to disassemble everything.
Thank you
Old Mar 7, 2023 | 12:57 PM
I want to add that this thing is 100% mechanical sound. As i can gear the plastic rubbing. Also the sound has this grinding noise, intermittently. This is not liquid or gas related
Old Mar 8, 2023 | 11:14 AM
kr98664's Avatar
Defrost door actuator?:
https://www.jaguarforums.com/forum/s...efrost-255852/
Old Mar 9, 2023 | 09:04 AM
Yes thats the one. I confirm. Im now trying to remove it
Old Mar 9, 2023 | 09:52 AM
The grinding noise was made buy that actuator or the blend door. I touched it when it was doing it.
my defrost had no issues but i hated the noise. I will post pictures on the original thread.
i even disassembled the motor and it looks good!
i will reassemble everything and try the reset procedure for blend doors
Old Mar 9, 2023 | 11:37 AM
I disassembled the motor and cleaned the swipe from the main gear to the motherboard.
i posted in the original topic (link above)
i just wanted to confirm it works now without having to purchase a new motor.
i also reset the vents after the procedure was done
Robert Rodriguez
Sep 25, 2021 01:37 PM
Philzick
Sep 9, 2021 06:50 AM
warrjon
Nov 25, 2017 03:09 AM
daro31
Nov 23, 2016 11:11 AM
Simon.h
Dec 22, 2014 09:45 AM
