s-type diagnostic tool
Old Jan 22, 2023 | 02:25 AM
knares's Avatar
Default s-type diagnostic tool
what is a good diagnostic tool for this model
thanks
i have a icarsoft i930
Old Jan 22, 2023 | 04:44 AM
Sheff928's Avatar
I have a Foxwell NT520pro which has done what I needed it to do on both my S-Types and X-Types. Some success on my X300s too as far as I recall.
It's been updated - see here
https://www.gendan.co.uk/product_FXNT530L.html
Old Jan 22, 2023 | 06:21 AM
knares's Avatar
OK, thanks
i will have a look
Old Jan 22, 2023 | 09:52 AM
S-Type Owner's Avatar
thanks
Just curious... what is wrong, or what do you find lacking with the i930?
Old Jan 22, 2023 | 06:14 PM
knares's Avatar
i dont know if there is any thing wrong or lacking with the i903, who would know unless they found a better one
i have a problem with my air con which i am trying to fix
Old Jan 22, 2023 | 06:42 PM
NBCat's Avatar
@knares, describe the problem and symptoms you're experiencing with the HVAC system.
Is the system fully charged with refrigerant?
Old Jan 22, 2023 | 10:50 PM
knares's Avatar
NBCat
the A/C works fine, hot or cold, its great
when i lock the car or just turn the ignition off, four and a half minutes later the air con fan turns its self on, which i am told is normal
but, it doesn't turn its self off, which is not normal, and it flattens the battery
Old Jan 23, 2023 | 04:03 PM
NBCat's Avatar
What you're describing is a symptom of a sticking or stuck thermostat, which causes the cooling module to come on as it's controlled by the PCM.
Note the 3.0 litre Duratec engine does not have a typical temperature sensor immersed in coolant to read the engine temperature. Instead, there's a head temperature sensor mounted on Bank1 that determines engine temperature and communicates it to the PCM.
Old Jan 23, 2023 | 04:20 PM
NBCat's Avatar
Do not rely on the instrument cluster gauge to determine engine temperature. Use a smart phone with the Torque app to connect the PCM through the OBD port with a Bluetooth interface to read live data from the PCM, including engine temperature.
Old Jan 23, 2023 | 05:15 PM
knares's Avatar
this is not the radiator fan, its the heater A/C fan
when i turn the ignition key on, it goes off, turn the ignition key off and four and a half minutes later it comes on again
Old Jan 23, 2023 | 06:43 PM
NBCat's Avatar
Sorry for the misunderstanding.
I suggest you follow, if you already haven't done so, the diagnostic procedure for the HVAC system in this thread:
https://www.jaguarforums.com/forum/s...ol-how-185002/
In this thread, Karl covers many of the issues that can cause the system to malfunction, and how to step-by-step diagnosis the cause(s)..
Old Jan 23, 2023 | 08:14 PM
knares's Avatar
thanks, reading that is going to keep me occupied
Old Jan 24, 2023 | 10:20 AM
kr98664's Avatar
Hmm, that sounds like a problem with the Air Conditioning Control Module (aka control panel), the brains of the system. Have you looked at getting a used replacement?
For control of when the fan runs, I think it's just a simple timer. X number of minutes after shutdown the fan starts, as you have observed. It's supposed to run a short time and then shut off, which unfortunately your fan is not doing.
Old Jan 24, 2023 | 11:34 PM
knares's Avatar
no, not yet
drmike
General Tech Help
Aug 5, 2021 06:02 AM
Stude51
Non-Jaguar Vehicles
Jul 13, 2021 05:15 AM
nalle
Mar 28, 2019 10:03 PM
JackJohn
Nov 1, 2016 05:36 PM
qwiketz
Jul 30, 2010 01:10 AM
