S Type Headlight Adjustment
Guest
Posts: n/a
Hi: After replacing a low beam headlight bulb (passenger side), although well intentioned, my attempts to adjust the beams ended up with all 4 lights being askew, both high and low as I also attempted some adjustment on driver side. Which I should not have as it was fine.My vehicle has the halogen bulb system. I used a phillips screwdriver to turn the obvious plastic gear assembly (one adjustment screw for each light). Several attempts to correct this, even downloading instructions from website have just made the situation worse. I've come to terms with the fact that these adjustment screws seem to adjust the left to right but I cannot seem to get adjustment up and down. I did see some mention of light adjustment here related to auto levelling but I'm not sure if my S type has auto levelling but even so would there not be up and down manual adjusting? Lights were good before I changed that bulb and decided to make "good" "perfect". I have these lights so bad that it is very difficult to drive at night. I had to do this when the nights are longest. Any help is greatly appreciated.
Thanks Pete
Thanks Pete
Your S-Type if it has Halogen bulbs does not have HID or self levelling.
There is two hex or allen head white plastic screws on top of each headlamp assy. One moves in and out and other up and down. I would start by facing it about 3 feet from a wall on level ground. Adjust lamps up first until they are just above your knee as you stand against the wall. Then adjust them left to right. At this point you want to back the car up about 20 feet from wall and they should be not touching each other. Drive it and see then make adjustments as necessary. Are you sure you installed the bulb correctly? Remove the back cover again and make sure the bulb is not loose inside. It is a common mistake.
Hope this helps.
Hope this helps.
