S- type headlight bulb change
Old Oct 7, 2014 | 10:39 AM
NikolaiDiqnov's Avatar
Default S- type headlight bulb change
I am having some troubles with the change of the headlight bulbs. I remove the plastic cover, then unwind the plastic bit on the back of the headlight itself and I can see the connector for the bulb. I am not sure what to do next. I am afraid I might brake something. A metal clip is visible but I am not sure if I should press it. Any advice is welcome. Also what brand would you reccomend - Philips, Osram or smth else?
Old Oct 7, 2014 | 10:49 AM
ONEsicJAG's Avatar
Push The Clip, Move It Out Of The Way. Then Pull The Bulb Out. I've Always Liked Phillips But, That's Just My Opinion.
BTW, It's Time You Add Your Car Details To Your Signature. It Helps When We Know What We're Looking At.
Old Oct 7, 2014 | 11:49 AM
Before i push the clip, should I first unplug the connector? As far as I can see this metal clip should be pressed on one side only. Is this correct?
Old Oct 7, 2014 | 01:15 PM
ONEsicJAG's Avatar
Yes One Side Only. I Don't Think It Matters About The Connector.
Old Oct 7, 2014 | 01:44 PM
Thank you. I will try it first thing tomorrow.
Old Dec 1, 2021 | 12:08 AM
gazzap's Avatar
Go to your owners manual. All information about changing headlight bulbs is in there.
Old Dec 1, 2021 | 03:04 AM
JagV8's Avatar
After 7 years! I hope not still trying to fix it...
stanjag
Dec 29, 2024 08:26 PM
Drew2006
Nov 24, 2015 11:14 AM
rudelover2
Sep 11, 2015 08:53 PM
WhiteTardis
Sep 2, 2015 10:32 AM
kesslari
Aug 31, 2015 04:53 AM
