S type oil pan gasket change
Old Oct 17, 2014 | 09:26 AM
NikolaiDiqnov's Avatar
Default S type oil pan gasket change
The time has come for my 2006 S-type, 2.5 v6 to get its oil pan gasket replaced. Is it absolutely necessary to move the engine up in order to replace the gasket. Also, is it a job that requires adept skills in engine repairs? I have a local mechanic who does the maintenance of my "cat" but now I am not quite sure if I can trust him with that. If you guys say that the job is rather difficult I will replace the part in my local Jaguar dealer.
Old Oct 17, 2014 | 10:49 AM
Here is one Rick did earlier https://www.jaguarforums.com/forum/s...ics-faq-52987/
He did raise the engine.
Old Oct 17, 2014 | 11:31 AM
joycesjag's Avatar
If the bolts are not rusty/seized then its not that bad of a project even if you are doing it on your back. A lift would go much faster.
Old Oct 17, 2014 | 11:43 AM
I have almost no technical knowedge whatsoever, so a mechanic will do the job . As far as I get it, it is not such a complicated job. I hope my mechanic can manage it. Also, I read about the gearbox and the shifter. Should they be disconnected? Is there any danger for the gearbox?
Old Oct 17, 2014 | 05:36 PM
joycesjag's Avatar
no worries on the shifter.
Old Oct 18, 2014 | 09:53 AM
While changing the pan gasket should I change anything else down there?
xjrjag
Nov 27, 2025 09:16 AM
stanjag
Dec 29, 2024 08:26 PM
BrentGardner
29
Dec 16, 2024 12:13 AM
Torrid
Feb 15, 2020 08:03 AM
Rupesh
Mar 25, 2016 03:33 PM
