S type R non-CATS
Old Jul 23, 2012 | 09:49 AM
bfsgross's Avatar
Ditto to Jagv8. If you should ultimately decide to do non-CATS, I'd heavily recommend using the Mina Galleries springs. They're compatible with stock struts. The Bilstien S-Type Sport struts are the way to go in this case.
Old Jul 24, 2012 | 07:09 AM
GT42R's Avatar
Eh... I would say in the interest of longevity and ride quality, non-CATS dampers, i.e. V8-Sport bilsteins, should be matched up with factory-spec V8 sport springs (the springs they were valved to run). Factory STR springs would be second best, and Mina's 3rd followed by H&R's as your last choice.
Old Jul 24, 2012 | 09:04 AM
93XJR-S's Avatar
after everyone's input, i purchased the front replacement CATS shock (ouch) and will call Mina on Monday for the springs Thanks for all your input!
Old Jul 24, 2012 | 09:52 PM
bfsgross's Avatar
Sounds good.
Old Jul 26, 2012 | 12:41 PM
JAGSTR04's Avatar
I'm know I'm late to the party but I have run Mina Springs and Stock Shocks w/CAT's on my S-Type R and I will tell you the Mina Springs will shorten the life of your shocks. The springs and Stock shocks where not designed to work together. I learned this the hard way. For the cost you could have purchased Arden Springs and Shocks for the same $$$$. I now have the Arden Springs and Arden/Billstein shocks w/CAT's on my STR and I couldn't be happier.
Old Jul 26, 2012 | 05:01 PM
93XJR-S's Avatar
do you have a source or more info on them ?
Old Jul 26, 2012 | 05:19 PM
Brutal's Avatar
I HAVE A GOOD CATS MODULE IF ANYONE NEEDS ONE PM ME $75
ALSO IDE CHECK WITH THIS BILSTEIN REBUILDER ABOUT REBUILDING CATS SHOCKS
Service
Old Jul 26, 2012 | 08:04 PM
  #28
bfsgross's Avatar
jagstr05, if the Mina springs are heck on the CATS, then the H&R's are hell on em. According to Chris of Mina, their springs are Arden "knock-off's".
Old Jul 26, 2012 | 10:43 PM
03Jagg's Avatar
I have had H&R springs with stock shocks with CATS for about 6 months, and so far the ride quality did not change. It still rides smoothly and corners well with 285s in the back, considering the weight of the car. Slightly stiffer than stock but compared to my friend's BMW stock suspension 335is with 19s, its still smooth and comfortable.
Old Jul 27, 2012 | 04:35 AM
  #30
JAGSTR04's Avatar
http://shop.arden.de/jaguar/s-type/s...b-mj-2002.html
Old Jul 27, 2012 | 04:51 AM
  #31
JAGSTR04's Avatar
BFSGROSS - They may be knock off's of Ardens but that doesn't mean they are built using the same materials or to the same quality or standards. I'm not bashing Mina in any way shape or form but what I will give you is my real world experience. I had Mina Springs with Stock Shocks w/Cats. In my opinion the Stock Shocks didn't last a very long time.
My point is if you want to optimize your ride there are some options that will work out better than Stock Shocks and or After Market Springs. I happened to choose Arden's spring and shock combo the second time around. If your serious about performance do your research. I made the mistake the first time around and wasted money.
Here are two options to consider Arden/Billstein or Spires/Billstein Coilovers.
Arden - http://shop.arden.de/jaguar/s-type/s...b-mj-2002.html
Spires - Jaguar S-Type Sports Suspension Package from Spires Specialist Jaguar Tuning
Old Dec 5, 2012 | 11:36 AM
  #32
93XJR-S's Avatar
Damn the Arden look to come in at $ 2500 US, I need to swap out the CATS shocks as they are worn and leaking they come in a bit cheaper @ 1400 with stock springs....decisions decisions need new tires also sigh never did wind up taking receipt of the CATS shocks really need all 4 new ones as the car is more of a marshmallow these days
Old Dec 5, 2012 | 12:24 PM
  #33
tbird6's Avatar
Has anyone found out how much the rebuild service of the stock CATS are?
Old Dec 19, 2012 | 12:40 AM
  #34
McJaguar's Avatar
Service
Bump:
has anyone ever used this rebuild service?
Old Dec 19, 2012 | 05:47 AM
  #35
bfsgross's Avatar
Not as far as i know.
Old Apr 8, 2013 | 09:00 AM
  #36
StypeR03's Avatar
Ok, since my wife's car is nothing more than a daily driver, I plan on using the Bilstein B4 Sports shocks. How difficult is it to use these non-CATS v CATS? If it were something that she used for more than a daily driver I would consider making the investment in the CATS but as it is I am going Bilstein sports. This is on the rear of the car btw.... any helpful replies would be appreciated?
Old Apr 8, 2013 | 10:55 AM
  #37
bfsgross's Avatar
The Bilstiens that fit the Sport model work well on the STR. The B4's won't fit at all. They're for regular S-Types (non STR).
Old Apr 9, 2013 | 11:12 AM
  #38
StypeR03's Avatar
So which Bilsteins do I need to get if not the B4s?
Old Apr 9, 2013 | 11:23 AM
  #39
bfsgross's Avatar
Use the same Bilstiens used for the S-Type 4.2 with "Sport" suspension. Part #'s Front: BE3-67430 Rear: BE5-6772
way2far
Aug 31, 2022 09:26 AM
ZJag
26
Sep 5, 2016 03:33 PM
KarimPA
Sep 12, 2015 08:15 AM
raffoulig
Sep 8, 2015 01:56 AM
KarimPA
Sep 3, 2015 07:32 PM
