s type r problems, heater and one engine mount.
Old May 24, 2013 | 02:09 PM
driver safz's Avatar
Default s type r problems, heater and one engine mount.
hi everyone ive just bought my self an str with sat nav, its extremly quick, loving the early days in it so far but the problem i got with it is:
the right hand side heater is hot dont go cold at all. whats possible reson and howmuch of a job?
the left front engine mount seems like its broken. what involves in changing that?
and finally the front left xenon bulb is very dim?
ide apreciate some help thanks saf
Old May 24, 2013 | 02:12 PM
Michael Star's Avatar
DCCV is bad.
Same as most others, it sucks.
Might need a new bulb, but they aren't cheap
Old May 25, 2013 | 11:34 PM
sprdav33's Avatar
I had a dim bulb and it ended up being the igniter on the end of the bulb not installed properly. I also had the parking light not working and it would come on and off when you banged on the light.
Old May 26, 2013 | 04:07 AM
thebiglad's Avatar
Originally Posted by driver safz
hi everyone I've just bought my self an str with sat nav, its extremely quick, loving the early days in it so far but the problem i got with it is:
1. the right hand side heater is hot don't go cold at all. what possible reason and how much of a job?
2. the left front engine mount seems like its broken. what involves in changing that?
3. and finally the front left xenon bulb is very dim?
I'd appreciate some help thanks Saf
1. Your coolant/heater valve is not functioning correctly - it's called a DCCV. Approx £70 to buy and an easy fix.
2. Don't know;
3. First check to ensure that it's not just a matter of the beam being set too low. If it is too low, the likelihood is the height levelling mechanism is broken. Do a search for Xenon headlight fix.
stanjag
Dec 29, 2024 08:26 PM
Jandreu
Aug 23, 2019 11:37 AM
Xj812
Oct 26, 2015 05:04 AM
martybmw
Aug 31, 2015 08:41 AM
bigw909
Aug 30, 2015 09:29 AM
