s type rear suspension groaning noise help!!
Old Mar 19, 2011 | 10:35 PM
mikewv100's Avatar
Default s type rear suspension groaning noise help!!
I have had the same problem for 3 months. I have a 2003 s type base 3.0. 70k miles
I have a groaning (creaking ) sound when hitiinbg bumps at low speeds or bouncing on the right rear end. I have taken wheel off , put jack under body and slowly jack up bottom of brake rotor. at about half of suspension travel i start hearing the squeaking and it seems to be coming from the pin-bushing from the upper control arm where it attaches to the knuckle. Is this a likely diagnosis??
I assume that changing the arm is the only solution if that is true. I cant find a bushing separatly. would you spend 98 on used or 320 for new upper control arm. Sorry for the long post.
stanjag
Dec 29, 2024 08:26 PM
BrentGardner
29
Dec 16, 2024 12:13 AM
Fraser Mitchell
Oct 1, 2015 04:06 AM
ogorir
US Southwest
Sep 1, 2015 10:05 AM
dpappyp
Aug 27, 2015 06:31 AM
