S-type Swaybar (Anti-roll bar)
Old May 24, 2013 | 06:31 PM
Tijoe's Avatar
Default S-type Swaybar (Anti-roll bar)
I've searched all I can find on the forum regarding S-type front and rear sway bars. Has anyone found and put on larger ones?
I read in the XK forum that there is a 20mm available for the XK rear, but at $350+ I'll build my own.
Anyone build their own?
Old May 24, 2013 | 06:36 PM
plums's Avatar
if you can move the end links, then shortening the side arms is effectively the same thing as increasing the diameter.
Old May 27, 2013 | 09:26 PM
Tijoe's Avatar
I crawled under my 2000 S-type project car and 2004 STR and measured the diameter of the rear sway bars. Both measured about 18.2 mm. I read elsewhere that S-types are supposed to have 17mm rear sway bar.
Also, I don't see how I can access the bolts that hold the sway bar to the sub frame. If one wants to change the bushings, it looks like you will have to drop the sub frame.
Has anyone changed the bushings?
I will plan on making my sway bar change to the sub-frame I am building before I put it in the 2000 S-type.
MrWhite
33
Oct 22, 2015 10:29 AM
Clare Jennings
Oct 4, 2015 05:43 PM
JagBrian
Oct 1, 2015 12:52 AM
dpappyp
Sep 29, 2015 01:28 PM
