S-type V8
Old Jul 19, 2024 | 11:56 PM
DLP's Avatar
DLP
Default S-type V8
a lot of water coming from the back of the engine, I don’t have the R with the supercharger just the plane V8 2000 s-type, really need some help thanks
Old Jul 20, 2024 | 06:30 AM
Peter_of_Australia's Avatar
More information?
With that little information I'd say you have a leaking coolant hose in the valley (between the 2 banks)....
Old Jul 20, 2024 | 09:48 AM
davidladewig's Avatar
There are 3 hoses that could be leaking or the expansion tank which is known to crack on this model behind the engine. If it is the expansion tank, the drip will be heavier between the fender and the driver door. The hoses will just have residue all over them. You'll need an extendable mirror to see under the hose. Good luck.
Old Jul 20, 2024 | 10:51 AM
NBCat's Avatar
The AJ28 has a heater return hose under the inlet manifold that is a known failure point. If memory serves, the JLR part number is NRA3976AA.Always check part numbers against the VIN for correct fitment.
Remove the inlet manifold and inspect.
ElVene31
Apr 27, 2021 01:18 PM
Candy's Kitty
Sep 19, 2012 07:04 AM
steven7413
Oct 6, 2009 02:41 PM
thisguy
Apr 22, 2008 05:49 AM
