seat height adjustment
Old May 2, 2012 | 06:33 PM
hifipm's Avatar
Default seat height adjustment
My power seat (driver and passenger) seem to be stuck at the highest position-when i try to lower I can hear the motor but it won't go lower-the tilt function works but it would be good to lower my seating position somewhat-good thing I'm not really tall- I assume there is height adjust on these.
Old May 2, 2012 | 07:36 PM
clubairth1's Avatar
Community Influencer
Depends on the car but since you have a STR you have the best seats and the most adjustments. Yes it goes up and down.
A bit odd that both seats do it. Have not had that reported before?
Old May 2, 2012 | 08:07 PM
hifipm's Avatar
Default Seats
Clubarth1 - thanks for confirming the seat height adjustability- I may ask at the dealer next time (may be soon for TCM stuff!)
Old May 3, 2012 | 08:34 AM
JagV8's Avatar
As I recall there is a separate module for each seat so to have both giving trouble.... Check in case there's a single item in common (fuse or relay).
Old May 6, 2012 | 11:13 PM
Illini's Avatar
When I got my STR last year I had a similar problem on the drivers seat. It was stuck full up and would not lower. My passenger seat was fine.
By unbolting the seat and disconnecting the appropriate motor, I was able to free the seat up. It seemed like the screw mechanism had gotten locked up at the end of its range and just needed to be put back in the right position to allow the controller to let the motor run again. I am tall, so I keep the seat fairly low now, but it has not frozen up again.
Old May 7, 2012 | 08:58 AM
hifipm's Avatar
Default power seat
Thanks Illini - i thought it must be something like that as I can hear the motor working- I'll check it out. Paul
scooternva
19
Oct 27, 2015 02:14 PM
Samheath100
Sep 17, 2015 10:03 AM
diablomkii
Sep 14, 2015 02:37 PM
Clamdigger
Sep 12, 2015 03:43 PM
jagent
Sep 12, 2015 09:10 AM
