Serious Coolant leak
Old Dec 24, 2013 | 01:14 PM
wigginout66's Avatar
2005 S type V8 4.2 (non S/C)
Old Sep 7, 2016 | 12:35 AM
Djfame's Avatar
Default Any luck?
I HAVE THE SAME LEAK ON 03 s type 4.2 non s/c. I can trace it to firewall somewhere?? Not at dccv or elsewhere has new water pump, thermostat assembly etc. The tank is fine I already replaced it! ?????? Put dye in and can seem to see it besides in the back not much room to see?? But leaks pretty gnarly after a while??
Originally Posted by texmex916
S Type V8 4.2 2003 (non s/c)
Hi All,
Thanks Wigginout66 for the info. my thinking is along the same lines... I don't think l'll be able to do much about it before Xmas but was thinking of getting hold of a $15 USB Borescope to confirm this Throttle output pipe is the cause of the leak before taking on the job of removing the Intake manifold.
Merry Christmas to All
and a
Safe and Happy New Year
Tex
Old Sep 7, 2016 | 05:38 AM
Datsports's Avatar
You need to look here >
https://www.jaguarforums.com/forum/x...on-s-c-149873/
Old Sep 8, 2016 | 05:38 PM
Djfame's Avatar
Originally Posted by Datsports
You the man I rented a coolant pressure tester and it concluded as to where I was seeing the dye but wasn't sure if there was a hose that went in to the block!!! It sure is leaking from there I'm guessing!!! That hose was a title loose by the TB body but leaking behind the TB so I'm guessing it has to be it! Def not water pump! Thanks and thanks to @mwilliams for his sharing of knowledge on this tricky leak!!! ✌🏾
arskemp
Sep 21, 2015 02:19 PM
OkieTim
Sep 8, 2015 04:48 PM
Xkr x100
Sep 6, 2015 08:50 AM
OkieTim
Sep 2, 2015 12:48 PM
