Shift knob replacement
Old Jan 23, 2011 | 07:59 PM
jordannray's Avatar
Default Shift knob replacement
Hello folks,
I have a 05 S-type, automatic. I got a replacement "leaper" shift knob that I would like to put on-
How do I remove the current one?
I just assumed it twisted counter-clockwise to remove- I gave it a good try and it didn't budge the slightest.
Is there something holding it in place, like a locking screw or something?
I suppose I could twist a little harder, but I am fearful of breaking or bending something if it is not meant to just be twisted counter-clockwise.
Please advise,
Thanks-
J
Old Jan 23, 2011 | 08:35 PM
cliff328's Avatar
Default To quote Chubby Checker..twist away...
I replaced the stock wood shift knob on my 2006 with a custom item from
a gentleman in Florida who does some amazing custom work.
Counter-clockwise...or, as the Brits say...'anti-clockwise' will do it.
You won't harm the shifter assembly; I suspect, but don't know for sure,
that the factory might use some type of compound on the threads to
prevent easy release.
Cliff
Old Jan 23, 2011 | 08:39 PM
aholbro1's Avatar
On both my 2003 and 2005 S-Type autos...they just screw off counterclockwise, *RH Thread" per RH rule. The chrome collar stays with the shifter. 2005 was much tighter than the 2003 first time I ever tried 'em.
Old Jan 24, 2011 | 05:33 AM
JOsworth's Avatar
Originally Posted by jordannray
Hello folks,
Please advise,
Thanks-
J
Take and wrap the chrome base in rubber or use rubber plier pads and grab it with pliers. It is only a lock nut but can be scratched. Then untwist the knob. Now, since your new knob has an emblem on it, you will want it facing a certain direction. I found that my custom knob would always loosen up. A trick I used on mine is to replace that chrome sleeve with a regular polished nut. I think it is 8mm bolt thread (but I really don't remember) but do know it is standard metric bolt thread so a nut is available at any big box hardware store. I threaded the nut down on the shifter then threaded my custom knob on. I then held the knob in the direction I wanted and used an open wrench to tighten the nut. My knob has stayed tight ever since.
Old Jan 24, 2011 | 09:02 AM
androulakis's Avatar
You have a pic of this nut.
I got an STR shifter I basically almost destroyed cause it wouldn't screw down all the way, left about a 1/8" gap. Me being captain overtighten decided it just needed some coaxing to get the rest of the way on. So i cranked on it... Too much apparently lol.
Take care,
George
Old Jan 24, 2011 | 10:09 AM
JOsworth's Avatar
Sure.... First smoke break I'll take a picture and come back and edit this..
Just a regular metric hex nut...
Attached Thumbnails Shift knob replacement-p9030136.jpg   Shift knob replacement-p9030137.jpg
Forcedair1
Sep 8, 2025 01:57 PM
RoyLittle0
May 25, 2023 02:38 AM
cissdm
May 3, 2016 06:02 AM
Bowman
Sep 15, 2015 06:54 AM
KarimPA
Sep 3, 2015 07:32 PM
