Simple? Rough Idle! Ideas??!!
Old Jun 12, 2015 | 07:24 AM
NBCat's Avatar
Originally Posted by jazzwineman
...Just curious- is my rpm at idle with and without the ac on in the normal range?...
Please see post 8 above.
...Is is possible to clean or even replace the TPS without replacing the while throttle body?...
What is the problem with this sensor?
Old Jun 12, 2015 | 09:22 AM
jazzwineman's Avatar
Thanks again.
relevant to #8- you indicated a number of sensors were sending info to the pcm to effectuate the correct air/gas, ect to get the idle or any speed within its parameters.
I am assuming the TPS is one of those and I am asking if that could be causing me the slight rough idle at idle with the ac on (although it appears nowhere else to be a problem) I have no codes. I believe that I have read where a TPS can get slightly oxidized or lose some carbon in its operation (that I am less sure of the truth of the last one) and if there is method to clean without screwing up the throttle body. My throttle body had only the slightest indication of anything from a build up of any sort and even a slight cleaning yielded a slightly discolored cleaner for a few seconds and that was that.
Tom in Dallas
Old Jun 12, 2015 | 03:18 PM
JagV8's Avatar
TPS is actually 2 sensors designed with different characteristics so faults can be detected. You sound to be thinking of old, crude, cars not S-Types. If you don't have TPS codes all is OK.
Harry Dredge
Oct 4, 2024 05:37 PM
Bcrary3
Feb 21, 2023 04:29 AM
Thang Nguyen
Oct 12, 2015 01:25 AM
joesoap
Sep 10, 2015 01:09 AM
Bowman
Sep 3, 2015 03:17 PM
