So many error codes have a bought a dud?
Old Sep 8, 2016 | 04:51 PM
Rozza's Avatar
Exclamation So many error codes have a bought a dud?
Hi Guys,
I have just bought my first jaguar and I am so in love with it I really don't think I will be turning back to any other car.
I have an S Type 2003 automatic 2.5 petrol.
I am getting intermittent abs warning light (DSC not available) after deciding the dealer is likely to fob me off until my warranty runs out I bought a icarsoft i930.
I uploaded the latest software onto it today and I am getting all of the following fault codes.
Have I bought a ******* and should I take it back and ask for a refund. Only problem is I really love this car.
Any advice would be much appreciated.
Thanks in advance guys
-Engine Control Module
Fault in communication with vehicle ECU
-Transmission Control Module
P1796 CAN controller circuit malfunction (bus off)
-ABS
Error C1268 Booster Mechanical Failure
-INSTRUMENT PACK
B2472 Fog lamp switch failure
B1567 Lamp headlamp high beam - circuit failure
B1875 Turn signal left and right switches active
B1689 Autolamp delay - circuit failure
B2329 Steering column reach feedback potentiometer open circuit.
U2522 CAN message timeout from the transmission control module.
B1681 Passive anti theft system transceiver module signal is not received.
U2523 CAN message timeout from the engine control module
B1202 Fuel sender circuit open
B2334 Column drive, tilt out of range high
U2521 Missing message from the ABS
B2333 Steering column for feedback potentiometer open circuit
U1900 CAN communication bus fault passive anti theft system.
U2518 Missing message from electron air temperature control.
B1470 Lamp headlamp input circuit failure.
-Climate control module
U2520 Missing message from instrument cluster
B2796 Driver solar radiation sensor circuit open
B2426 Passengers solar radiation sensor circuit open
B1676 Battery voltage out of range
B1264 Foo servo motor circuit failure
B1263 Vent servo motor circuit failure
B1242 Recirculating air flow door actuator circuit failure.
B1262 Defrost servo motor circuit failure.
B1265 Cool air servo motor circuit failure.
-Drivers door module
All ok
-Rear electronics control module
U1041 Scp vehicle speed signal invalid or missing data
B1201 Fuel sender circuit failure
-Audio unit
All ok
-General electronics control module
-Electronics Peking brake
All ok
-Restraints control module
All ok
Old Sep 8, 2016 | 05:52 PM
JagV8's Avatar
A lot of those might be old (unless you've cleared them and they all came back) and a fair few due to a low / flat / dead battery.
If the battery isn't fairly new or isn't fully charged you commonly get false codes. Battery is #1 suspect.
You have so many codes and so varied that I can't see them all being true.
But do be aware that mostly they stay in modules forever unless someone forces a clear (and most tools don't even read the modules other than PCM - above called ECM) .
You could do with the codes from the PCM (expect a pending P1111) and also check the fuel trims.
A lot of people like to note codes, then if they're old clear them and see which if any come back, in what order and how soon.
The full workshop manual with codes PDFs is a free download. Just the codes PDF for the PCM is a good place to start and in your case maybe the ABS one (they're in the Chassis - C codes - one). The codes PDFs are (or at least some are) on www.jagrepair.com as well as on here.
Old Sep 8, 2016 | 06:25 PM
QuartzSTypeR's Avatar
Also check for water in the trunk.
Old Sep 9, 2016 | 01:49 AM
Rozza's Avatar
Thanks jagv8,
The only problem is with clearing the fault codes is that I have bought from a dealer and it's still within my 30 days warranty.
If I clear the codes it might put me in a weaker position taking it back. Some codes might be an issue but don't return in time for me to return the car.
The car seems to work and I tried to test the abs and that seems to work as well I haven't managed to test it when the warning light is present.
Maybe I should take back to the dealer with all the codes, put it in writing and if it does come back after my 30 days atleast I can prove they were there before.
Thanks again guys I will research the abs fault, this is the one that's worrying me the most.
Old Sep 9, 2016 | 02:22 AM
JagV8's Avatar
I'd be concerned about the PCM (aka ECM) since things such as fuel trims (& codes) say how it's running. Suppose the trims are out then you can expect (even with no codes) cat conv damage in time and they're not cheap.
In general terms this is true for any modernish (about 1995-on) car (using petrol, the diesels have another set of issues).
If you're in England/Wales i.e. "English" law applies then you can ask them to repair what's wrong at their cost or reject the car - but the sooner the better and before 6 months or it gets tough.
Howie
Sep 1, 2016 07:08 PM
Salu498
Aug 29, 2016 12:13 PM
new2jag2016
Aug 27, 2016 01:02 AM
Peter Jones
Aug 24, 2016 08:12 PM
TonyG
Aug 24, 2016 12:47 PM
