Spacer help
Old Aug 25, 2011 | 11:15 PM
Bmwm5lover's Avatar
Default Spacer help
Hello all, having a difficult time locating local spacer supplier.
One supplier can get me spacers from a Volvo 850 that read as follows;
your car is:
bolt pattern = 5x108
hub size = 63.3
lug size = 12x1.5b "bolt"
the spacer i found from volvo 850 and c70:
hub size = 65
lug size = 12x1.75b "bolt"
yes you can get a hub ring to make the difference. i'm not sure if i can get those hub rings, i need to ask my supplier, he is on vacation.
the spacers i can get called system 2. picture is attached. so its a spacer only with extended bolts.
problem i just notice the lug size or bolt size is different from both cars so you going to have a problem. since the one comes with the spacer is 12x1.75. so you got no use for those and you have to order a new set of extended bolts which is 12x1.5.
hope everything is clear. let me know if you any other questions.
Will these spacers work?
Old Aug 26, 2011 | 07:03 PM
joycesjag's Avatar
Sorry can't be of much help on your above question, but.......Get ready to alot of reading:
Jaguar Forums - Jaguar Enthusiasts Forum - Search Results
For future use, try this:
Click the "SEARCH" button (NOT the RED one) at the top of any forum page
Click "Advanced Search"
Type in "your keywords"
Scroll down a bit to the "S Type Forum"
"Search Now" button
your welcome in advance
Old Aug 29, 2011 | 09:54 PM
Panthro's Avatar
You could try here.
Mac Allan
Jul 20, 2020 05:46 PM
XJ8JR
Sep 29, 2015 06:59 PM
al_roethlisberger
Sep 11, 2015 10:04 PM
metalmarty
Sep 11, 2015 07:05 AM
