Spark plug change
Old Aug 14, 2016 | 02:31 AM
cully's Avatar
Default Spark plug change
I have just replaced the inlet manifold on my 3ltr S type 2003 after changing the spark plugs and I have found a rubber cover sat over the top of one of the old plugs, obviously come out of it's mating coil.
Do I need to replace this cover into that coil ( manifold off again)
What are my options?
Paul
ps didn't remove the manifold completely as I was unsure how the pipe was released that's on the underside of the manifold. Is it a push fit or?? I didn't want to brake it finding out.
Thanks again
Old Aug 14, 2016 | 06:23 AM
Datsports's Avatar
Are you shore it's not the rubber spark plug retainer for inside your spark plug socket ?
Old Aug 14, 2016 | 08:22 AM
cully's Avatar
Thanks Andy, that's exactly what it is!
I noticed the last plug I installed fell out of the plug skt. and thought "that's odd" but didn't relate the two.
Any comments on my ps?
Thanks again
Old Aug 14, 2016 | 08:44 AM
joycesjag's Avatar
I believe you are referring to the brake booster vacuum line quick connect on the back of the intake. It operates like an pneumatic quick connect. Push in, pull out.
Old Aug 14, 2016 | 11:36 AM
cully's Avatar
That's one concern but the brake booster hose seems to have been pushed up tight to the back of the manifold with no movement available to "push then pull" out.
the other was the pipe that fits directly under the manifold??
Old Aug 14, 2016 | 01:30 PM
Datsports's Avatar
You have to push the black ring around the booster pipe in then pull the pipe out .
Not sure about the one under it but should be strait forward to figure out .
WhiteJag
Apr 5, 2016 03:22 PM
shimonek
Apr 4, 2016 09:49 PM
Travis O'Gallagher
Apr 3, 2016 02:49 PM
oyster
Apr 3, 2016 09:41 AM
Interior
Jan 24, 2007 04:50 PM
