Spark plug terminal broken
Old Apr 14, 2017 | 01:49 PM
Johnny V's Avatar
Talking Spark plug terminal broken
Has anyone has have their spark plug terminal stud broken inside the well before? I caught it early coming from work, oil was dripping out (on to the Lower manifold) and had smoke coming out the exhaust (unburned oil). I looked inside and thought That was was weird. Usually breaks by the electrode or by extracting it. Please educate me, I am looking into my finding of what else happened
Camera is broken got it off my laptop.
Old Apr 14, 2017 | 02:08 PM
Mikey's Avatar
Which engine?
Removing the spark plug for inspection will tell the rest of the tale. I've seen something like this before and it wasn't pretty. I hope this is not the case here.
Old Apr 14, 2017 | 02:20 PM
JagV8's Avatar
If not 100% sure you can tackle it, get a good mechanic immediately. Unfixed it is damaging the cat. conv.
Old Apr 14, 2017 | 03:25 PM
Johnny V's Avatar
I'm really upset it is turning out to be more then spark plug. I am finding sand and a small spring near the thread, and rest of my spark plug wells. It was before they change the cylinder numbering 1-6 . I'm starting to think someone use a leaf blower near my exhaust when we were cleaning the parking lot (like in the army) not sure. Worried about my pistons, but not concluding to that. Don't know were a small spring came from or the other side. Gotta redo my valve cover gaskets.
Old Apr 14, 2017 | 03:32 PM
Ducmon's Avatar
Get one of them horoscopes such as this and have a look inside the cylinder. It will show you if there is any other damage on the piston etc.
Borescope Camera Potensic 2 In 1 Semi-Rigid Micro Usb/Usb Endoscope Inspection | eBay
Old Apr 14, 2017 | 03:39 PM
Johnny V's Avatar
hmmm I need one of those scary. Here is the spring I found.
Old Apr 14, 2017 | 03:59 PM
Mikey's Avatar
Don't quite follow this.................
Old Apr 14, 2017 | 04:27 PM
Johnny V's Avatar
It's really bad misfire with a broken terminal stud broken on spark plug. I found a spring near the thread making it worse. I'm sure it's not leaf blower incident. Originally tried to see what caused the terminal stud to break, still working on it.
Old Apr 14, 2017 | 04:48 PM
Johnny V's Avatar
Okay guys/gals listen carefully if ever break a terminal off a spark plug. Chances are you might stumble on a small spring (sometimes in other wells). So it is not from the piston chamber. Got to redo my gaskets boring.
Old Apr 14, 2017 | 06:06 PM
Datsports's Avatar
The small spring is from the inside of the tip of the coil (COP),
Looks like some one was ruff when fitting/removing that plug , the sand I don't know about .mystery
