starts and stalls like no gas, tank full
Old Dec 10, 2018 | 02:01 PM
mile high's Avatar
Default starts and stalls like no gas, tank full
A nice warm day in Colorado, drove to the store about 8 miles away, a few block from there leaving a signal light the car hesitated as I took off, strange I thought-Park car at store and returned about 30 minutes later, car started but had trouble running, stalled, restarted, stalled and again but ran less each time (1-2 seconds ) now no start what so ever.
Checked fuel injection, fuel pump and ignition fuses, all ok. 3/4 tank gas. Do fuel pumps die that suddenly. Any suggestion out there ?
Old Dec 10, 2018 | 02:08 PM
S-Type Owner's Avatar
You might want to check the fuel filter; has it ever been changed...?
Old Dec 10, 2018 | 02:41 PM
mile high's Avatar
Yes, but maybe a good ideal. Thanks
Old Dec 10, 2018 | 03:58 PM
NBCat's Avatar
Check to see if there is fuel pressure at the schraeder valve on the engine above Bank 2. If not, fuel pump may be failing or seized.
Here are the fuel system specifications:
Old Dec 10, 2018 | 05:05 PM
DigitalDisaster's Avatar
Sounds like what we went through for a couple weeks with our 2000 4.0 when the fuel pump failed.
Old Dec 10, 2018 | 06:16 PM
mile high's Avatar
How repair kit ordered, (same as Ford) with new filter. Will keep you posted
rf69
Oct 14, 2016 03:47 PM
kalexander
Jun 16, 2016 11:16 AM
motogirl_94518
Jun 12, 2012 01:56 PM
tkd_540
Jan 21, 2011 08:26 AM
Simprof
Nov 15, 2010 05:36 PM
