STR Fuel Pressure specs & whats yours running at?
Old Dec 25, 2012 | 12:32 PM
03Xtype's Avatar
Default STR Fuel Pressure specs & whats yours running at?
AllData shows these specs for the STR, can some one confirm if these are correct?
V8, Supercharged, Denso Engine Managment
Idle speed 3 bar (43.5 psi)
Wide Open Throttle 5 bar (72.5 psi)
My 2003 STR fuel pressure is running at:
Idle stays around 54 psi
WOT stays around 58 psi but spikes up to 62 psi during shifts
I suspect the right side fuel pump is failing.
Old Dec 25, 2012 | 04:22 PM
03Xtype's Avatar
Fuel pressure was measured via IDS.
Old Dec 25, 2012 | 07:25 PM
clubairth1's Avatar
Community Influencer
I had a fuel rail pressure sensor fail on my 2005 STR. For troubleshooting I drove around a good bit with a mechanical fuel pressure gauge taped to my windshield! Search for code P0191 if you are interested.
I would say you are in the proper fuel pressure range. I got between 45-65 psi driving around.
If you have a pump going down there are several codes it should set?
Are you down on power?
toronadomike
Jan 22, 2026 10:13 PM
dsnyder586
Dec 29, 2024 07:39 PM
Charlene n John
Sep 28, 2015 06:01 AM
Sprayall
Sep 3, 2015 07:49 PM
rachelstr
Sep 3, 2015 12:59 PM
