Strange Engine Moaning (Video)
Old Jun 25, 2016 | 12:19 PM
Paul Mayo's Avatar
Question Strange Engine Moaning (Video)
Hi All,
I've recently purchased a 2001 Jaguar S-Type Sport V6 which has recently been making a moaning noise intermittently after some hard acceleration.
The sound appears to be coming from under the bonnet and in first thoughts sounded as if it was a belt rubbing on something in the engine bay, however after some close inspection this is not the case. It only appears when you apply very slight acceleration and can be heard both inside and outside of the car (more so inside).
You will be able to hear the noise in the below video:
Thanks for taking the time to read this, any help would be much appreciated!
Paul
Old Jun 25, 2016 | 12:21 PM
Paul Mayo's Avatar
Sorry, the video did not display:
Thanks,
Paul
Old Jun 25, 2016 | 02:13 PM
Renocat's Avatar
I'd think that could be power steering pump or idler pulley failing, I'd have it looked at before something bad happens at the worst time..
And how'd Your car get the steering wheel on the wrong side, someone at the factory reading the assembly instructions wrong?
Old Jun 25, 2016 | 02:25 PM
Paul Mayo's Avatar
Thanks for the reply Reno,
Would you happen to know if the Idler pulley or power steering pump would cause the sound to be intermittent though? If I youtube some sounds of them failing it appears that it is a constant noise they make.
Also, I have to mention that the power steering is brilliant, the car can be steered with a little finger on the top!
Thanks again,
Paul
Old Jun 25, 2016 | 03:23 PM
NBCat's Avatar
Probably the simplest way to determine the source of the noise is to remove the belt and see if the noise stops. If it does, check the bearings on the idler pulleys, water pump and alternator for roughness when spinning them by hand.
Old Jun 25, 2016 | 03:25 PM
NBCat's Avatar
...And how'd Your car get the steering wheel on the wrong side, someone at the factory reading the assembly instructions wrong?
I thought for the longest time the cars leaving Castle Bromwich with the steering wheel on the left were mis-built...
Old Jun 25, 2016 | 10:22 PM
Renocat's Avatar
Some people would say all English cars were misbuilt, but we know better.
al_roethlisberger
Dec 3, 2016 03:35 AM
that guy
Jul 5, 2016 03:34 PM
Gingerorange
Jun 30, 2016 02:18 AM
Homersimpson
Jun 27, 2016 09:37 PM
hooverhoff
Jun 23, 2016 09:25 AM
