Strange noise when turning
Old Apr 21, 2012 | 10:23 AM
FloridaJag's Avatar
Default Strange noise when turning
Hey all -
A few months ago, my S developed a strange noise when turning left in a parking lot. It sounds like a small pop when the weight transfers during a left turn at a speed of maybe 5-10 mph like when turning into a parking space or maybe just making a left turn to cross a busy intersection. When I do this at speed (30-40 mph or so), the pop is not noticeable.
I made a visual check of the front suspension and everything seems intact. The rubber boots are in excellent shape up front. Several weeks ago I replaced the upper control arms and I thought that would do the trick. Although the car rides a bit better thanks to that, they weren't the cause of that irritating popping sound.
Has anyone had similar experiences?
I bought a set of ball joints just in case, but I would think that ball joint symptoms would be different in that stability would be lost at speed.
Thanks for your help.
Old Apr 21, 2012 | 11:26 AM
wilson's Avatar
have you checked the transmission fluid in the power steering well?....
Old Apr 21, 2012 | 12:32 PM
FloridaJag's Avatar
Fluid levels are okay.
Old Apr 21, 2012 | 12:38 PM
Mikey's Avatar
roll bar bushings.
Old Apr 21, 2012 | 01:29 PM
2000JagLvr's Avatar
Check your brakes. Could be loose pads/rotor.
martybmw
Apr 2, 2016 04:55 AM
Horus
Sep 18, 2015 05:39 AM
Burdedw
Sep 12, 2015 10:39 AM
raulan
Sep 10, 2015 12:43 PM
simo5555
Sep 9, 2015 06:22 AM
