Stuck Crankshaft Position Sensor
Old Oct 6, 2023 | 01:33 PM
Millarjs's Avatar
Default Stuck Crankshaft Position Sensor
2003 S-Type R Supercharged v8
Trying to replace CKP Sensor (Crankshaft Position Sensor). It is stuck in the Bell housing. Have used Penetrating Solvent to no progress. Is there a trick to getting these things loose? Heat? Drill? Pounding?
Old Oct 7, 2023 | 10:14 PM
kr98664's Avatar
How much room do you have for access?
You may have to take out the remains in pieces. Maybe a right angle drill with a short bit? Measure the protrusion on the new sensor. Shorten the non-cutting end of a drill bit so you can hollow out the broken sensor, without going all the way through and damaging sensor ring on the flywheel.
With any luck, you could drill out the guts of the broken sensor, leaving only the metal shell. With a small chisel or awl around the edge, collapse the shell and remove it with pliers.
Old Oct 8, 2023 | 06:46 AM
Millarjs's Avatar
Thanks.
I like idea of controlling drill length to protect flywheel.
Old Oct 10, 2023 | 12:10 PM
xalty's Avatar
electric ratchet with drill chuck thingy attachment. little bit of chisel work to get the sleeve off
otherwise trans is coming out
dcjag22
Oct 4, 2022 06:47 AM
feniks138
May 25, 2021 03:19 PM
3kgtjunkie
Aug 4, 2020 10:06 PM
randyb
Aug 19, 2014 02:29 PM
Idrivejags
Dec 1, 2008 07:26 PM
