Stuck Passenger Seat
Old Dec 5, 2023 | 05:45 PM
Davidnaber's Avatar
Default Stuck Passenger Seat
My passenger seat will move forward and backward, but just barely. When I move it forward, it begins to turn into the gear shift console. I’ve undone the two front bolts to where I can tilt the seat back and look at the track and wires. However, I can not see into the track. Any tips, tricks, or directions that would make is feasible for me to clean out the track and get my seat back to moving the way it should?
Thanks so much!
Old Dec 5, 2023 | 06:46 PM
Peter_of_Australia's Avatar
As I do not know, if the S-Type has an electric passenger seat on all versions: Is your passenger seat electric?
You removed the 2 bolts in the front? What about the 4 bolts in the rear?
With all bolts removed, you can tilt the seat fully back, but mind the wiring loom, which you have to disconnect - and before you do that, pull the fuse for the seat-airbags.
Old Dec 5, 2023 | 07:01 PM
Davidnaber's Avatar
Yes, it is electric.
I don't see bolts in the back, more like hinges.
I see all of the electrical wires, but no way to access the track where the spinning bolt is.
Old Dec 5, 2023 | 07:07 PM
I think the rear bolts are hidden under plastic covers, which need to be removed first. They have a little sideways-screw of their own.
bocatrip
Sep 3, 2021 06:09 AM
attaboy
Dec 12, 2018 09:14 AM
new mexico
May 17, 2018 02:18 PM
rendo
Dec 30, 2014 02:54 PM
