Suggestions for coolant to use for Jag?
Old Jan 28, 2016 | 01:52 PM
adriana_lgns's Avatar
Default Suggestions for coolant to use for Jag?
Previous owner used one I cannot find. Suggestions on what coolant to use? Manual says 50/50 WSS M97B44, colored orange, Extended Life Coolant. Was Thinking Prestone DEX-COOL 50/50 Prediluted Extended Life, but heard it is more for GM or Ford?
Old Jan 28, 2016 | 02:21 PM
Dex-Cool is fine, that's what I and several others use.
Old Jan 28, 2016 | 03:05 PM
Mikey's Avatar
Does it mention the Jag/Ford spec on the label?
Old Jan 28, 2016 | 03:48 PM
You know it does don't you Mikey? :-)
Q: What automobile industry specifications do your antifreezes meet or exceed?
A: Prestone® Antifreeze/Coolant meets or exceeds the performance requirements of the following specifications:
  • ASTM D3306
  • SAE J1034
  • GM 1825M
  • Ford ESE M97B44-A
  • Chrysler MS7170
  • General Services Administration CID A-A-52624
Prestone® Dex-Cool® Premixed LongLife® Antifreeze/ Coolant meets or exceeds the following industry standards and specifications:
  • GM 6277M
  • Ford WSS-M97B44-D
When tested in ASTM D 1384, D 4340, D 2570, and D 2809, Prestone® Dex-Cool® Premixed LongLife® Antifreeze/ Coolant will meet the chemical, physical property characteristics and performance requirements of the following standards and specifications:
  • GM 1825M
  • GM 1899
  • Ford WSE-M97B44-A
  • Ford ESE-M97B44-B
  • DaimlerChrysler MS 7170 and MS 9769
  • General Services Administration A-A-52624
  • ASTM D 3306
  • SAE J 1034
  • ASTM D 4985
Prestone® LowTox® Antifreeze/Coolant meets or exceeds the performance requirements of:
  • ASTM D5216
It also meets the corrosion protection requirements of:
  • ASTM D3306
  • ASTM D4985
  • GM 1899
  • GM 1825
  • ASTM D1384
  • ASTM D4340
  • ASTM D2570
  • ASTM D2809
Old Jan 28, 2016 | 05:41 PM
Mikey's Avatar
You'd think I'd remember by now given how often the question comes up.
Old Jan 28, 2016 | 06:18 PM
davidladewig's Avatar
ZEREX G-05 I got it at the auto parts store. That is what their book called for on my car. I'm sure other stuff works fine too.
Old Jan 29, 2016 | 07:49 AM
aholbro1's Avatar
Welcome to the forum, Adriana. Make sure you drop by the new member section and introduce yourself, so a moderator will take notice of you and upgrade you to full-status when you meet all the prerequisites.
If you are the original owner of the car, you should be fine following the spec advice and adding any of the coolants claiming to meet the required spec. If you are NOT the original owner, I would advise draining, flushing with distilled water, then adding your preferred coolant, either pre-mixed or undiluted with distilled water to achieve the 50/50 mix. Although the color can be a nice indicator, you don't know what previous owners may have added to the coolant system, and certain coolants, when mixed with the "pink lemonaide" that the 03/05's I own came from the factory with, form a jelly-like substance that clogs up the coolant passages in your heater core and/or radiator.
Like David, my coolant of choice is the Zerex G-05, but I've always done a number of "drain-refill-run" cycles with distilled water until I get "water-colored coolant" out of it before I add the G-05. Generally, it has taken an average of 12 gal of distilled. Not bad at $0.88/gal.
Gopi Hira
Feb 13, 2016 07:24 PM
willic
Feb 2, 2016 03:30 AM
Roughrhoads
Feb 1, 2016 11:32 AM
o1xjr
Jan 28, 2016 08:29 AM
Jason Souhrada
Jan 27, 2016 03:58 PM
