Sun Roof Problems
Old Jul 8, 2019 | 05:35 AM
Flappers's Avatar
Default Sun Roof Problems
Hello all, I've recently been getting water coming in through the sun visor fittings and the cabin lights in the centre of the headliner. Coupled with that has been that the sunroof works intermittently. Sometimes opening normally, most of the time sticking half way or needing repeated button presses to move it a few mm. Eventually, it'll stop moving completely stuck half way and I need to close it. Can anyone offer any support please ?
( 2001 3 litre Stype )
Old Jul 10, 2019 | 08:10 AM
aholbro1's Avatar
I'd start by clearing all four sunroof drains. Several threads here on how to do it, some with pics. It' s more common that the floorboard fills with water, but I think a few have reported leaks from overhead due to clogged drains. Do you park it outside much? Any trees around? This would accelerate drain clogging but is not necessary to have the occurrence.
Old Jul 14, 2019 | 03:49 PM
Flappers's Avatar
Thank you, yes its sat under a tree daily 🙄 I'll figure out how to flush the drainage pipes as a start. Thanks for your help.
Old Oct 17, 2019 | 08:10 AM
Tony K.'s Avatar
Having the same problem with my 2004 S-Type. Vacuumed 2+ gallons of water out of the footwell yesterday after heavy rain. Opened the sunroof which was completely filled with water.
Over 2 gallons!
Beside the standing water in the footwell this is the only sign of water damage
" Several threads here on how to do it" can't find them.
Tony
Old Oct 17, 2019 | 08:21 AM
Tony K.'s Avatar
I see some posts now. Didn't realize there were several pages when you search. Look forward to trying these clean-out methods.
Thanks Jaguar Forums!
Tony
2004 S-Type 4.2L V8
Old Oct 17, 2019 | 08:26 AM
neilr's Avatar
If you look at the four corners of the sunroof well you will see the 4 small drain holes. Gently push some plastic wire (strimmer wire maybe) and see if you clear the problem.
I had this happen once but when I tested the drains before cleaning, they worked fine again!!!
Old Oct 17, 2019 | 04:17 PM
Tony K.'s Avatar
Default Clogged drain tubes
I tried using trimmer wire and 16 gauge copper. I can only get about 6 in in.
rgreuling
31
Oct 30, 2025 11:54 AM
Mike Frayne
Sep 2, 2020 01:48 AM
vincev
Apr 26, 2017 09:36 PM
Angrycanuck
Aug 25, 2016 10:25 AM
Jaguar S-TYPE MAN
Dec 29, 2011 01:30 PM
